Results 1 to 20 of 23
Thread: Transmission tail shaft leak
07-07-2009, 09:55 AM #1
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
So after the motor swap i noticed that i have had a pretty constant leak from the trans tale shaft. the other day i got under the car and it looked like the drive shaft was out of the trans a little more than normal. is this possible? everything is mounted up in the same spot as before. Or could it just be that the seal is bad? i dont think i over filled it, but i will check again this weekend. I havent had much time to tinker with it but any help would be great. Thanks
07-07-2009, 09:58 AM #2
- Jan 2006
- Shepherd, Michigan
m6 or a4? none the less..the torque arms mount on the tail shaft creating a lot of stress on it from any car that isnt stock..i woulldnt doubt a stress fracture on the tail shaft..especially with a 408 stroker
07-07-2009, 10:08 AM #3
07-07-2009, 10:11 AM #4
07-07-2009, 10:14 AM #5
07-07-2009, 10:21 AM #6
- Feb 2006
Stock- 2002 Camaro
oh ya and my torque arm is attached to the cross member not the tranny
07-07-2009, 05:20 PM #7
Replaced ours back in March -- actually had some fun trying to install the new seal. I do not have a seal driver and it kept popping back out as I tapped around the perimeter with a plastic hammer.
07-12-2009, 02:01 PM #8
- Jan 2009
- North Jersey
Had mine replaced under warranty. Didn't know I had a leak til I took mine to the dealer for a diff chatter. Had a pinion seal and tailshaft leak.
07-12-2009, 02:48 PM #9
- Feb 2006
Stock- 2002 Camaro
well i have been to every auto part store in the area and none of them have it. looks like im gunna have to go to the dealer
07-12-2009, 02:57 PM #10
- Jan 2009
- North Jersey
Have you tried eBay?
07-12-2009, 03:27 PM #11
- Feb 2006
Stock- 2002 Camaro
i just dont understand how its so hard to find
07-12-2009, 03:27 PM #12
Thats sad when the local chain stores don't carry a common seal
Have a close look at the tailshaft bushing while you're in there too. If it's worn and letting the yoke move around more than it should, the seal can't do it's job well. Sometimes this even causes vibrations that people chase around with wheels, tires and even the driveshaft itself,,,lol.
Alot of people have replaced the seal for a leak only to find it comes back a couple months down the road. Because the bushing is worn beyond spec.
Just something to keep in mind.
07-12-2009, 03:31 PM #13
- Feb 2006
Stock- 2002 Camaro
Thank you sir. i will def check that out. im new to this whole transmission thing. kinda one of those things that scare me
07-12-2009, 04:22 PM #14
my car is peachy as usual-thought I would let you know.
07-12-2009, 04:37 PM #15
07-12-2009, 07:41 PM #16
07-12-2009, 07:44 PM #17
07-13-2009, 05:08 AM #18
07-13-2009, 05:14 AM #19
- Oct 2007
- Beaver Dam KY
07-13-2009, 03:10 PM #20
- Feb 2006
Stock- 2002 Camaro
$61 and a few headaches later....... I got the part on order. And no they didn't use lube
Question: 4L60E Tail Shaft Housing
By kingls1 in forum Automatic TransmissionReplies: 2Last Post: 12-11-2016, 12:08 PM -
Transmission Tail shaft leaking
By Guerrillakilla13 in forum General HelpReplies: 11Last Post: 10-12-2013, 04:48 AM -
broken tail shaft housing
By heath26 in forum Automatic TransmissionReplies: 0Last Post: 11-03-2012, 05:00 PM -
Help: Rear Tail shaft seal
By kingls1 in forum Manual TransmissionReplies: 0Last Post: 05-13-2011, 08:42 AM -
tail shaft seal leaking
By autoxr in forum Manual TransmissionReplies: 1Last Post: 06-25-2007, 04:50 AM
