Results 1 to 20 of 39
Thread: Overheating ls1
    Jul 2009
    Memphis
    Midnight Blue
    1999 Camaro Z28
    Overheating ls1
    Just replaced my waterpump and radiator and my car is still overheating, when i stop antifreeze spits out of the jug cap... anyone have a clue whats going on?
    Bragg NC
    Met. Sunset Orange
    01 SS
    Did you bleed the air out? I would start with a new Rad cap and you may have to check the thermostat.
    J
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Pressure bleed it. The engines in these cars sit so level with the radiator that unless you jack the front way up or pressure bleed it the air will not come out.
    SATX
    2000 Trans Am
    just remove the line that goes to the TB before you fill up the radiator with antifreeze, pour AF and as soon as the fluid starts comming out of the line connect it back. turn on engine and leave the cap open when you start the engine. once the thermostat opens if the block had air in it, it will bubble and the fluid level will lower down, so top off till it sits level for a while.
    F BODYS RULE maxwax's Avatar
    GEORGIA
    2001 CAMARO
    I am assuming you did put in a new thermostat, if not that could be the problem, my car would overheat at extend range in speeds over 70ish, but would run around 210 at 55 mph , the problem was a piece if rubber from the inside of the thermostat that had actually came apart and had stuck in the thermostat itself and caused it to not work properly.
    Member Goldcuffs's Avatar
    Aug 2008
    Florida
    2000 Trans Am
    Does it overheat at highway speeds or just when stopped?
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Thumbs up
    Quote Originally Posted by maxwax View Post
    I agree, an old corroded thermostat could be stuck closed, replace it with a "fail safe" thermo, if they fail, they will stick in the OPEN position.
    SteveC
    Military Muscle :usa: MYSCZ06's Avatar
    Columbia,SC
    Millienum Yellow
    2003 Corvette Z06
    blown head gasket?
    Stockitie Stock Stock 95camaroZNC's Avatar
    Raleigh NC
    1999 Trans Am
    When you put everything back were you careful and avoided putting the radiator back in ontop of the wiring harness for the fans, are the fans coming on? This is the problem i had when i replaced the radiator because my dumb ass numb skull friend who supposedly helped restore the 65 mustang he drives sat it right ontop of it and burned it out.
    If thats not it, thermostat for sure inless you have blown the head gasket driving it hot.
    Jul 2009
    Memphis
    Midnight Blue
    1999 Camaro Z28
    yes the fans are coming on but not until in hits 220 dergees
    Start it up and monitor the temp of your radiator hoses. Whatever your thermostat is rated for, the hoses should start to warm up a little above that temp and within a few minutes should be hot.
    If the thermostat is stuck closed, or is not opening all the way, the hoses will not get hot. Shut it down as you have either a bad stat or the cooling system is airlocked.
    11's "CLUB" SS SLP2's Avatar
    Silsbee, Tx
    Y2K Camero SS
    Quote Originally Posted by SVG210 View Post
    X2
    blead the air
    Johnny
    Member Bandit1's Avatar
    Philly PA
    2002 TA WS7
    when i bleed my radiator with the cap off after a little bit it starts to over flow and than shoot out like a gyser. any thoughts? i am as well having a slight overheating problem.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Quote Originally Posted by Bandit1 View Post
    How many times have ya bled the system?
    Philly PA
    2002 TA WS7
    tried to do it 2x and get some bubbles everytime till it blows out
    North Jersey
    2004 GTO M6
    What else have you done to yours? Have you ever flushed your system?
    Philly PA
    2002 TA WS7
    had the water pump replaced bout a year ago but didnt have the problem till last night.
    the temp gauge went up right before the red so i shut it down figured it sucked an air pocket from some where
    Philly PA
    2002 TA WS7
    is there a way to test the relays? i suspect the fans r not working.
    North Jersey
    2004 GTO M6
    Do you have a power probe? It's a tester with a wire that runs off 12 volts to run power to a harness to see if there is power going to an accessory. That way, you could "jump" the fans to see if they are running without the car on.
    Philly PA
    2002 TA WS7
    i dont have a power probe, i do have a volt meter.
  1. overheating
    By lancesT/A in forum General Help
    Last Post: 07-13-2007, 12:12 PM
  2. Always something.. Car overheating.
    By juiced99ws6 in forum General Help
    Last Post: 07-13-2007, 01:40 AM
  3. OverHeating! Need help
    By 02bluez28 in forum General Help
    Last Post: 05-13-2007, 01:13 PM
  4. overheating
    By lancesT/A in forum Firebird / WS6
    Last Post: 05-09-2007, 07:45 PM
  5. overheating 02 z-28 (not sure)
    By chuckt619 in forum General Help
    Last Post: 09-10-2005, 10:40 PM
