Results 1 to 3 of 3
Thread: Posi died
    - STOCK ish - Sarge91's Avatar
    Fairhope, Alabama
    2002 Camaro SS SLP
    Posi died
    I can do 2 wheel burnouts, but even in the rain.. i mean dead poring, i cant spin both tires anymore. Cant even do a donut..
    So is my best bet to rebuild rear? I dont need a upgrade unless its a little more than a rebuild. I was told i can replace the carrier and the seals...
    Any suggestions?
    2002 Camaro SS A4 - SLP# 2951 l MS4 l LT's w/ORY l F.A.S.T 78 & TB l Borla l Cutout l CME l TCI 3500 l 3.23's l !emissions l !sway
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    The cheapest thing you can do first is check the fluid and make sure it is not over filled and flooding the unit. If thats ok siphen out enough fluid to put in 2 bottles of GM LSD additive and then take the car out and do figure 8's for a while and then see how it reacts.
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    Does you car have the torsen diff in it or did it come with the optional slp auburn posi. If it has the torsen I doubt you screwed up the gears inside the auburn clutch packs however are a different story.
  1. Help: My ss died.
    By 98maro in forum General Help
    Last Post: 12-24-2010, 08:52 AM
  2. my car died!
    By Faught in forum General Help
    Last Post: 10-30-2010, 02:22 AM
  3. aburn posi vs eaton posi units
    By TOOSHORT2000TA in forum Drivetrain
    Last Post: 04-05-2009, 06:01 PM
  4. My Brother DIED 11-2-07.......
    By LS2Tuner in forum Almost Anything Goes
    Last Post: 11-24-2007, 02:38 PM
  5. the lt-1 died :(
    By vecaj in forum LT1
    Last Post: 04-24-2007, 07:08 PM
