Thread: Trans Mount
07-02-2009, 11:55 AM #1Junior Member
- Jun 2009
- Clear Lake City, Texas
Black- 1998 & 1979 TA
Trans Mount
I replaced my trans (auto) mount on my 98 a couple of weeks back. I am now getting vibration in the car. I went back with the ploy mount from Jegs, seems the mount is to stiff and I am transfering the vibration to the body. Has anyone else had this problem. I am thing about swapping out this one out with the original mount from GM Parts Direct, part number 22174970 for 59 bucks.
07-02-2009, 12:04 PM #2
The poly mounts are much stiffer than the rubber mounts, and will transfer more vibrations/noise into the cabin. Its just the tradeoff for having stronger mounts.
Only way to get rid of the extra vibrations is to go back to the stock rubber mounts. I don't trust the stock ones very much though, when I got my car, the stock trans mount was torn completely in half. I'll live with the extra vibrations to keep the powertrain in place. However, my car is not a daily driver, either.
07-02-2009, 12:08 PM #3
wesman summed it up. i have a poly trans mount and its my daily driver. i'd rather run the poly mount
07-02-2009, 12:11 PM #4Junior Member
- Jun 2009
Yep, mine was ripped in half too. Mine is my daily driver, not sure if I am going to replace or not. I have a 30 mile drive one way.
07-03-2009, 04:34 AM #5
I had a piece of thin soft rubber placed between the poly mount and the cross brace, and it helps minimize the vibration.
SteveC
07-03-2009, 09:00 PM #6
Get the Energy Suspension trans mount, then cut/grind the 2 preload bumps off then mount it up. I've ran my car this way for over 6yrs with no problems, and with very little vibration/noise increase in the car.
07-03-2009, 10:12 PM #7
07-03-2009, 10:24 PM #8
they vibrate for the first month, then after it goes away i mean not completly but wont vibrate like it just to. i place a piece of old tire rubber between the mount and the tranny and i have no vibrations here.. but if you keep breakin the original mounts this has to do with the reinstallation of the transmission for some reason before i never have to replace the tranny mount, but after the unistalled the tranny for some work and reinstalled i was breakin the oem mount every 2 months or so
07-04-2009, 08:00 AM #9Junior Member
- Jun 2009
I will try it, thanks
96 & 98 trans mount
By redbird98 in forum Firebird / WS6Replies: 6Last Post: 10-30-2010, 10:43 AM -
pic of trans mount
By 02WS6dream in forum General HelpReplies: 4Last Post: 08-12-2007, 04:56 AM -
M6 Trans mount
By ss~zoso~ss in forum Manual TransmissionReplies: 3Last Post: 04-10-2007, 07:46 AM -
Trans Mount
By silver98TA in forum Automatic TransmissionReplies: 3Last Post: 08-26-2005, 08:57 AM
