Results 1 to 20 of 27
    Member adham's Avatar
    Newport News, VA
    2000 Pontiac Trans Am
    shaking/missing/hesitating...
    i am experiencing alot of shaking while ideling
    i have a 2000 trans am and i just got new headers cats and plugs and wires
    the ses light turned on but there is no misfire
    the code i got was P0410 secondary air injection system malfunction
    what might be causing the shaking?
    maybe the o2 sensors?
    anyone experienced this before??
    please help
    Newport News, VA
    help please
    Newport News, VA
    also...i am only getting roughly 14mpg but i think thats normal?????
    Member Capster78's Avatar
    Newport News Va
    1998 WS6 M6
    did you make sure all your vacume lines were reatached?
    Newport News, VA
    u mean AIR and EGR?....yes
    Newport News, VA
    help
    Newport News, VA
    help
    Junior Member AMMP's Avatar
    Crestwood,KY
    1999 Trans Am WS-6
    Check to see if the Air pump fuse is open (blown). Let me know when you find out. I may have some more info once you let me know.
    Newport News, VA
    i dont think its blown because when i first turn on the car i hear the air going through the salp lid and everything and then it cuts off after a while
    Toledo
    98' dark blue 85' red
    98 & 85 Trans Ams
    I would check the fuse, because the fact you only "think" fuses are there to be blown a weak spot in an electrical line. They can go at any time.
    Newport News, VA
    ok, the pump runs fine
    the passenger side metal tube is kinked really bad so the problem is there right?
    i think i kinked it when i put the new headers in because i had to bend them to fit the new ones.
    yeah, so do i want to try to straighten the tube or should i buy a new tube?? and from where??
    could this malfunction be causing the shaking ir no?
    thanks
    Newport News, VA
    help
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    The kink sounds like it's what caused the dtc code....as for the shaking, my guess is the headers. Try to secure the exhaust better...after I put my cats and y pipe on it shaked a lot more at idle and transmitted the vibration into the interior.
    Newport News, VA
    so what do i do?
    what did u do?
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    I put the mufflex bump stop hanger(used to stop pipe from banging floorboard) on the driverside Y-pipe...helped a lot. But I also don't have long tubes...but it might still work for you. Or bring it to a muffler shop and see if they can fabricate some support for your system.
    Newport News, VA
    mine doesnt bang or touch the floorboard
    Newport News, VA
    so where can i get the metal tube to replace the kinked one?
    Newport News, VA
    come on help me out here
    Senior Member
    Jacksonville, FL
    I don't think the kinked tube is causing the shaking - you can pull the AIR PUMP fuse and disable the whole secondary air system if you want to check (it'll throw code P0412 though). Assuming the plugs are OK and gapped correctly, next thing I'd look at is to be sure you don't have a plug wire arcing somewhere on the headers, and they're all on TIGHT. I've helped on 4 header installs, only problem was after a couple days once on SLP headers we found the #6 plug wire burnt and arcing - no SES but engine was running rough - found it by starting the car in the dark with the garage lights off - also had a slight "clicking" noise. You can also try resetting the PCM, and maybe even an idle relearn, but with some miles after the install it should have already learned. Hope this helps, just a couple ideas...
    Senior Member
    Jacksonville, FL
    Forgot, I'd visit the dealer for the metal air tube, the gasket is PN 12553617. If you need the PN for the tube I can look it up for you if you want to get them online. Again, reason I don't think the air system is causing the shake is because it shuts off after a couple minutes, then only comes on once in a while while cruising.
  1. Hesitating
    By lovemytaho in forum GM Trucks
    Last Post: 06-29-2014, 05:29 PM
  2. HELP!! WOT Sputtering and Hesitating
    By Cobra Killer in forum General Help
    Last Post: 08-21-2009, 08:13 PM
  3. hesitating after 30 min on highway
    By jmatt07 in forum General Help
    Last Post: 05-24-2009, 03:26 PM
  4. my 98camaro z28 is hesitating when i accelerate
    By ajonesz28 in forum General Help
    Last Post: 04-09-2009, 09:23 AM
  5. Trans hesitating when I hit the gas.
    By 2001redssagain in forum Automatic Transmission
    Last Post: 10-25-2006, 10:45 AM
