    Hometown
    1998 Trans Am WS6
    Help me pick a convertor for my ta
    I have a 1999 TA with Longtube headers o/r y pipe GMMG catback, ls6 intake,P&P TB, slp lid, and I am looking to replace my stock convertor with a new one. I am thinking of a yank 3600 but not sure. I dont drive the car much just to local shows/cruise nights and will eventually get it up to the track. Also what size convertor should I go with 9.5 inch or bigger? thanks
    Member 666ws6's Avatar
    Greenville, SC
    2000 Trans Am Ws6 #2946
    Well, I'm no converter expert, but you can chek my sig to see what I have. I like my SY 3500 stall, which should be close to 3600 (can't recall diameter size).
    It's most definitely still very streetable and does well at the track. I've had it in so long now I forget I even did a stall and sometimes I wish for a change. Took my 14 hours to do on my own, in my garage on stands... don't want to do that again unless it breaks.
    2000 WS6 TA #2946 - A4, Best 1/4: 12.5s @111mph.
    SLP LTs, 228r Cam, SY 3500, Shift kit, LS6 intake, underdrive pulleys, lid, p&p TB, Borla w/ cutout, Pro-kit springs, poly all around, Hotchkis suspension, 3.90 gears, tuned.
    mercersburg pa
    hugger orange
    2004
    a 3,600 should work great for you.
    after its in get a tune and drop or delete your torque management, lower shift delays and shift points/ pressures.
    most important thing you NEED to do with a stall is get a tranny cooler!
    Hometown
    1998 Trans Am WS6
    I ordered a B&M trans cooler yesterday and I am going to install that over the weekend
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    I also would replace the stock flexplate with a TCI SF29 race grade unit, you need to remove 3 bolts anyway to change the converter, you might as well pull the remaing bolts and change the flexplate while you are in there.
    Jeg's sells the unit.
    SteveC
  1. Question: Convertor Question
    By Bama99z in forum Automatic Transmission
    Last Post: 10-06-2009, 11:02 AM
  2. Question: Stall Convertor
    Last Post: 09-01-2009, 12:58 PM
  3. Convertor Install
    By JRuffryders0930 in forum Automatic Transmission
    Last Post: 09-24-2006, 06:29 PM
  4. torque convertor
    By bandit95 in forum Automatic Transmission
    Last Post: 03-08-2006, 03:58 PM
  5. Has anyone used a GM 3500 6.0l convertor?
    By kingcrab in forum Automatic Transmission
    Last Post: 11-02-2005, 01:35 PM
