Thread: It finally happened..
06-30-2009, 08:16 AM #1
I bent a pushrod! Or at least I think I did... either that or my dam cheap headers are leaking again!
anyways it coming from around piston #2 so I'm gonna replace the header gasket and I might as well do the pushrods too already... my question is, what pushrod size and what are some good ones that won't kill my pocket?
I believe hi-po answered this already for me but I forgot where it was
ops:
06-30-2009, 03:15 PM #2
Stock heads? Whats not stock in the vavletrain? 7.4 is the stock length needed. Just call COMP and ask for stock LS1 pushrods. I think a set of them run 100-120 bucks. I just sent a set back and recieved somewhere around there.
What happened? Miss a shift? Why do you think you bent a PR?
06-30-2009, 09:51 PM #3
All my drivetrain is stock. And i shall call them, thanks!
And I think its that cuz I have hit the rev limiter before and it sounds something like a loose ticking noise (im not real good at describing noises
) when i rev the engine a little im guessing to about 1500 but i can clearly hear it coming from the top of piston #2.. its either that or a header leak but im pretty sure its the pushrod or maybe a loose rocker? Im not really thinking its a header leak again.. ill try to get some video of it tomorrow when i move it, i havent moved it since it started with the ticking
and if its not pushrods, well i might as well do it before it happens
07-02-2009, 04:59 PM #4
well i tried to get some video but my crappy g1 sucks a it and i have no idea what happen to my dam camera but anyways i used the old waterhouse trick and pinpointed the noise to an exhaust leak coming from under the header gasket in piston #4
07-02-2009, 05:21 PM #511 years of bangin gears
- Jan 2009
- North Jersey
So it's a header leak? I have been told stock manifold gaskets are the way to go with headers as the gaskets that come with the headers tend to leak. I dunno if it's the materials used to make the header gaskets or what.
07-02-2009, 05:33 PM #6
yea i've always used the stock gm ones made outta copper or aluminum, idk wtf theyre made outta of but in not about to pay $50 for the other "aftermarket" ones... efff that!!
07-02-2009, 07:15 PM #7
i reused my factory 190k mile exhaust gaskets with my headers,no leaks!
So it finally happened the other day....
By SajoR in forum Camaro / SSReplies: 23Last Post: 04-20-2011, 07:53 PM -
Finally happened
By flipsutter in forum Manual TransmissionReplies: 35Last Post: 09-08-2009, 08:26 AM -
Finally Happened... 4.00 a Gallon
By OnEbAdReDSS in forum Almost Anything GoesReplies: 70Last Post: 05-16-2008, 08:18 PM -
It Finally Happened
By CJREX in forum Camaro / SSReplies: 16Last Post: 11-03-2007, 05:01 PM -
finally, finally it happened
By leviathon 88 in forum Kill StoriesReplies: 20Last Post: 06-04-2007, 04:41 PM
