Thread: 98 camaro v6 rebuild question
06-29-2009, 07:59 PM #1
So i have decided to rebuild the engine on my camaro v6 after having the rod bearing problem.
How much am i looking at?
Is there any place you guys recommend in So Cal?
Thank you
06-29-2009, 11:48 PM #2
if your looking at rebuilding it yourself, call up Summit racing.
they will have everything you need, but if you shop around you should beable to find alittle better prices
06-30-2009, 05:14 PM #3
I'm not sure what you mean. Replace heads? It could be several thousand dollars to do that+ if you're not doing any of the work yourself.
07-01-2009, 03:28 AM #4
i don't have the experience or the knowledge to rebuild on my own yet. so i am looking for shop to do so.
And i haven't taken it to the shop yet so i don't quite know if i have to complete rebuild or not.
07-01-2009, 03:45 AM #5
Shop around I'd say. Ever think maybe of finding a junk yard motor that runs?
Maybe cheaper in the long run to have a shop replace the engine rather than rebuild your 3800.. Just a thought..Good luck with it. Depending on the shop it's possible they would have your engine for weeks doing a rebuild. Maybe only a week for a replace. Most shops will install an engine you provide I'd think.Last edited by Smittro; 07-01-2009 at 03:56 AM.
07-01-2009, 08:29 AM #6
07-01-2009, 07:36 PM #7
If I were you, especially if the cost of a rebuild is several thousand, I'd look into getting a V8 engine. There's another part of the forum where you can ask about what might fit. Used from a junked car would save money, but the car's value would be higher with something else.
07-01-2009, 09:40 PM #8
98 ls1 rebuild question?
By 98goldta in forum Internal EngineReplies: 10Last Post: 07-01-2011, 04:54 PM -
Help: 98 z28 camaro ls1 and trans rebuild question??
By augie1209 in forum Camaro / SSReplies: 4Last Post: 06-03-2010, 02:20 PM -
Question: Rebuild Question
By Orrin's Z in forum Manual TransmissionReplies: 1Last Post: 11-06-2008, 05:04 PM -
Rear End Rebuild Question
By FormulaFiend in forum DrivetrainReplies: 3Last Post: 04-04-2007, 10:13 PM -
rebuild question
By shady milkman in forum Manual TransmissionReplies: 12Last Post: 03-25-2007, 06:16 PM
