Results 1 to 11 of 11
    Hometown
    1998 Trans Am WS6
    Ls6 coolant plugs and pipe ?
    I ordered the coolant plug and pipe kit from WS6store but it didnt come with the little gasket plates under the pipe. Do I reuse my old ones or do I need new ones, I called all the dealerships and no one has them in stock so not sure if I even need them. thanks
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    gasket plates ???? mine didnt come with any gasket plates (at least i didn't think they did..and mine runs fine
    Jun 2009
    coon rapids, MN
    2000TA
    has any one tried tapping these coolant holes and using small fuel fittings and small braided lines?
    Arizona
    Quote Originally Posted by brian r View Post
    They should be included, and already be attatched to the bottom. When I bought mine they had the o-ring gaskets already on there and ready to go.
    If they didn't come with the o-rings attatched and ready,,,then send em' back.
    Shepherd, Michigan
    98' trans am
    mine were like that..is that what he was referring too ?
    Arizona
    I'm not sure if he is just not seeing the little 0-rings already on the pipes,,,or if someone actually did take them off before shipping.
    They should have been in original sealed GM plastic bags. Thats how GM sells them new and thats how all the venders get them as well.
    If they were not in the factory sealed bags then someone opened them up before they were shipped,,,,,in which case it's possible someone pulled the 0-rings off.
    Hometown
    1998 Trans Am WS6
    there is little o rings on the bottom, but i wasnt sure if i still need the little gasket plates that come on the stock line ?
    Arizona
    That sounds correct as is. Bolt them on and you should be ready to go.
    Hometown
    1998 Trans Am WS6
    sounds good thanks everyone
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    the original design had the o-ring gaskets in a plate. the current design has the o-rings in the coolant line ends.
    Hometown
    1998 Trans Am WS6
    I finally got it all together this weekend, car runs great and lloks awesome I painted the intake to match the car. Thanks for all the help everyone it really helps!!!!
  1. HELP: Tranny, Coolant, and Spark Plugs
    By GOR1LA in forum General Help
    Last Post: 09-06-2011, 06:31 AM
  2. Question: part numbers for the LS6 coolant pipe and plugs
    By JayTA98 in forum General Help
    Last Post: 05-15-2011, 01:07 PM
  3. Coolant bypass lines/plugs LS6 Swap
    By Vertiviper in forum External Engine
    Last Post: 04-25-2010, 02:42 PM
  4. LS1 LS6 Intake Manifold Coolant Pipe Kit
    By splitfinger09 in forum Parts For Sale / Trade
    Last Post: 11-11-2007, 09:53 AM
  5. ls6 intake coolant plugs or extra front coolant pipe?
    By mikes ss in forum External Engine
    Last Post: 12-03-2005, 04:13 PM
