Thread: headlight problems
06-23-2009, 04:51 PM #1
headlight problems
everytime i lock or unlock my car my head lamps lift and close. then the passenger side makes a loud noise. the car is a 02 trans am. HELP!!!!
06-23-2009, 05:05 PM #2
06-23-2009, 07:36 PM #3Junior Member
- Mar 2008
- Portsmouth, VA
Navy Blue Metallic- '99 Pontiac Trans Am
06-23-2009, 07:40 PM #4Senior Member
- Nov 2006
- Indianapolis
Your headlight gear(s) are stripped. Do a search, there are many threads about this issue.
06-23-2009, 10:14 PM #5
06-24-2009, 10:15 PM #6Custom Painter/Tech
- May 2009
- Plainwell, Mi
Flame Red / Orange Custom- 1998 Trans Am
Yeah its definitely you head light motor gear there is a nylon gear and a metal screw gear the screw gear is tearing up the nylon gear you can get a new brass gear to replace it. I had the same thing happen to me i had to take out both headlight motors pull the gear covers off take out old crappy nylon gear replace with the brass gear don't forget to lubricate the screw gear then put the epoxy on the gear lid cover edges only! or you risk messing everything up then put the cover back in place and make sure it is in place properly and let it dry for about 15-30 minutes repeat the process for the other side and you will never have to worry about "The buzzers" as i called them lol it is about $90 bucks total for both kits and you can get the kit here >>>> http://www.bfranker.badz28.com/headlightfix/ hope this helps
06-27-2009, 07:47 AM #7Junior Member
- Feb 2008
- Milwaukee
SOM- 2001 SOM WS6 408
I have 2 brass gears if you want to buy them for less than $80.
Headlight problems
By AfterYou in forum General HelpReplies: 4Last Post: 10-28-2009, 12:10 AM -
Headlight problems?
By JC70SS in forum Firebird / WS6Replies: 4Last Post: 05-03-2009, 10:36 AM -
Headlight problems
By wiwood in forum Firebird / WS6Replies: 3Last Post: 09-24-2008, 07:41 PM -
headlight problems
By camarostripes96 in forum LT1Replies: 5Last Post: 10-25-2006, 06:51 PM -
headlight problems
By blackramairvert in forum Firebird / WS6Replies: 2Last Post: 02-07-2006, 10:13 AM
