Thread: studdering after WOT
06-22-2009, 07:29 PM #1
WHen first started my car drives fine. M6 cheatr cam...
After a WOT run or after it warms up it seems to lose it's tune. It wants to die at anthing less than 75% throttle. I tried to clean my battery cable because its corroded. Can this be the tune. It seems like something electrical. It still runs like a bat out of hell at WOT.
06-22-2009, 07:37 PM #2
I did just remove my AIR, but it was doing that before.
06-24-2009, 09:21 AM #3
06-24-2009, 03:16 PM #4
without seeing a log of the occurance, my suggestion would be in the tune yes.
06-24-2009, 04:23 PM #5
06-24-2009, 05:19 PM #6
the tuner is correct. the car doesn't lose it's programming. something has happened IE sensor go bad, plug wire, spark plugs worn, etc...
06-24-2009, 05:34 PM #7
No codes? No, it does not 'lose' the tune.
06-24-2009, 07:05 PM #8
Thanks, hopefully this corroded wire being replaced will help. The car actually acts as if it has a short. However, the short seems to be overwhelmed at WOT when demanding a lot of voltage. I've even noticed lately that the blinker blinks slowly when the car is malfunctioning.
08-16-2009, 12:47 PM #9
After months, and hundreds of dollars at different shops, I found a vacuum leak. There was a vacuum hose that ran pass my battery to the ac/heater vac tank. The acid corroded the hose. Problem fixed. The beast is back.
help with studdering
By RealLiveMD in forum Computer & TuningReplies: 54Last Post: 02-23-2010, 01:58 PM -
studdering and almost stalls
By shady milkman in forum General HelpReplies: 30Last Post: 11-13-2009, 04:48 AM -
serious engine studdering all of a sudden
By jmatt07 in forum General HelpReplies: 23Last Post: 06-25-2009, 05:50 AM
