Thread: Microedge help.
06-20-2009, 03:24 PM #1
Microedge help.
All I want is to spray and use the micro edge as a window switch.
I don't have the tps wire hooked up, I do have the narrowband o2 hooked, everything else is wired. I'm using one stage and the brown ground is going to the ground relay of the solenoids. IT WILL NOT SAY SPRAYING, IT says GR1 run and Armed.
Setup:
Widwband Stock o2
Trig mode off
rpm mid
rpm pulse 2p
Stages gr 1-4 Stage 1
Window
Reset 950
Lowest gr1
Drop 1500
Shift 4500
min rpm 1&2 3000
max rpm 1&2 6300
Delay:
Leanout off
pedal 2 &1 0 sec
Shift 2 &1 0 sec
launch 2&1 0 sec
Trigger 2 o.o
reset Disabled
min o2 0.00 even though I have the narrowband hooked up
max a/f 13.5
min a/f 7.00 lowest it would go
I don't know what's wrong, I go I hit WOT and it just keep saying armed. It's not being triggered by the rpms even though the rpms are clearly registering.Last edited by RealLiveMD; 06-21-2009 at 01:21 PM.
06-07-2010, 07:54 PM #2
Followup and the rebirth of an old thread. I got my car to spray. The problem now is that it has never been able to spray using the lockout feature. The window switch works , and i've just been reaching s down and hitting the armed switch to turn on the nitrous. With 3.90s now, I need this thing to work. If I set gear one to none. Then it will not spray, regardless of how many gears I go through. It will simply say Triggered but not Spraying. Not sure if there is anything else to do. I think I just got a defective one.
Setup:
Widwband Stock o2
Trig mode on
rpm mid
rpm pulse 2p
Window
Reset 950
Lowest gr1
Drop 600
Shift 4500
min rpm 1&2 3000
max rpm 1&2 6300
Delay:
Leanout off
pedal 2 &1 0 sec
Shift 2 &1 0 sec
launch 2&1 0 sec
Trigger 2 o.o
reset Disabled
max a/f 13.5
I thnk its trig 1 that's set at 4.20 and it works because the spray works fine if I don't try to use the lockout feature. What would make it just say triggered and not spraying?
06-08-2010, 02:16 AM #3
call em...
04 C5 A4 Torch Red - sold
2009 CTS4 Ice Black - sold
2013 1500 Silverado Z71 - sold
02 Z/28 M6 Onyx Black All Options - Sold
2014 Caddy CTS4 - DD
2016 Silverado 2500HD
2020 Caddy XT6
2020 2SS Vert
06-08-2010, 10:08 AM #4
You obviously havent tried that suggestion before. Let's see, option 3... then 1 min hold, then all sales reps are busy at this time. Leave name number, etc. When I get a rep, he is generally courteous, it's just not going to happen very easily. Anyway, I was hoping that someone on this site would have had a similar problem. I had it about a year. I assumed user error, but I beginning to think that I just got a bad one.
06-08-2010, 11:39 AM #5
I believe 2 members on here work for HSW, try to PM 1 and see if they can get you on the phone.
06-11-2010, 07:25 PM #6
Call Nick at Harris. He helped me out alot on mine. Mine didn't do anything at all when I first installed it.
Did you ever hook up the TPS wire? You will need that.
06-11-2010, 07:37 PM #7
06-11-2010, 07:45 PM #8
Good to hear. They were always pretty fast at getting back to me. There tech support is one of the best I've found so far. Especially after what they did for me. Which earned my loyalty and business.
06-17-2010, 10:34 AM #9
Harris is a good organization; I never have reservations about sending my own customers their way for parts.
Question: does anyone have a microedge installed on there WS6?
By 5.7mmImportkilla in forum Firebird / WS6Replies: 0Last Post: 12-30-2010, 02:54 PM -
NEW! The MicroEDGE gets a buddy!
By Nick@HSW in forum NitrousReplies: 2Last Post: 09-08-2009, 11:35 AM -
microedge controller?
By jmatt07 in forum NitrousReplies: 9Last Post: 06-21-2009, 03:37 PM -
which o2 do i hookup microedge to?
By jmatt07 in forum NitrousReplies: 4Last Post: 05-27-2009, 07:53 PM -
New MicroEDGE nitrous controller from HSW!
By Matt@HSW in forum NitrousReplies: 15Last Post: 09-19-2008, 10:25 AM
