Results 1 to 16 of 16
Thread: trick flow 215 heads
06-19-2009, 09:26 AM #1Junior Member
- May 2009
- hitchcock, texas
- 1978 280z- ls1-v8
Will these heads flow increase beyond .600 lift? They are recommending roller rockers with these heads. The cam I have selected has a.585 lift on both valves.
06-19-2009, 10:51 AM #2
I would say yes, but not by much. But I can't find a flow chart for them that goes over .600
06-19-2009, 10:54 AM #3
06-19-2009, 03:01 PM #4Junior Member
- May 2009
- hitchcock, texas
- 1978 280z- ls1-v8
what hp do yall think the motor once properly tuned will put out? Fast 92mm intake and throttle body,compcams 232/236 and 585 lift lsa112 stock bottom end with heads milled to creat 11.1 comp ratio. Haven`t selected the injectors yet. Any suggestions? Will have custom headers made, but not sure what lenght to run.
06-19-2009, 03:18 PM #5
I'll say well over 400+ rwhp, maybe 440.
what for a tranny are you running?
06-19-2009, 03:24 PM #6Junior Member
- May 2009
- hitchcock, texas
- 1978 280z- ls1-v8
I am running a4l60E. I Probably just lost a hundred horses on the estimates.lol
06-19-2009, 03:26 PM #7Junior Member
- May 2009
- hitchcock, texas
- 1978 280z- ls1-v8
I was told that I would be putting out 515hp at the crank. That was before the fast intake. According to TEA.
06-19-2009, 03:43 PM #8
If your not going to run NOS, turbo, or supercharge it you should run the other head they have. They just came out with it in march and they help keep stock compression with out having to mill them. You could just change pistons to a +cc and get in to the 11 range. Here is the info. http://www.trickflow.com/pressreleases/GenXStreetHeads/
Call thier tech department and talk to them. I called them and he said the new LT1 and lsx heads are better matched for NA engines. He said this head was designed for the truck motors and LS1's not realy ment for ls2,3..Last edited by JaycenK; 06-19-2009 at 03:46 PM.
06-19-2009, 03:51 PM #9Junior Member
- May 2009
- hitchcock, texas
- 1978 280z- ls1-v8
I orderd these heads a few days ago and these are the ones that TEA suggested. Unless you are running a strip car, these are pretty good heads.
06-19-2009, 03:51 PM #10
06-19-2009, 04:03 PM #11Junior Member
- May 2009
- hitchcock, texas
- 1978 280z- ls1-v8
Yep a 1978 280z. with a zz4, 195 afr`s, 236/242 520/540 lsa 112 ,rpm man,750 holley, 700r4, 3200 stall and 3.90 gears and a suffacating single exhaust w/shorty headers. I twas turning 11.50`s w/1.68 60' times at 117 mph. I am praying to heaven that it will be solidly in the tens.
06-19-2009, 04:06 PM #12Join the PHK @ thephk.org
- Nov 2007
- Studio City, CA
Red- 2001 Camaro SS
would you choose genx street heads over AFR 205's?
Join the PHK2009 LS1.com Calendar Car
06-26-2009, 09:55 AM #13Junior Member
- May 2009
- hitchcock, texas
- 1978 280z- ls1-v8
Ok, now i am wondering with the same heads a little larger cam and stroked out to a 383. What do yall think that will give me at the crank and at the wheels? Still running the 4l60e. I ahve a stall out of a 700r4. If it won`t work in the 4l60, what should I replace it with?
06-26-2009, 10:17 AM #14
06-26-2009, 04:30 PM #15Member
- Jun 2009
- coon rapids, MN
red- 2000TA
42# injector should do.
07-08-2009, 03:30 AM #16Junior Member
- May 2009
- hitchcock, texas
- 1978 280z- ls1-v8
Question: Anyone have trick flow heads?
By 02ssmaro in forum Internal EngineReplies: 0Last Post: 06-16-2011, 01:15 PM -
Question: Trick Flow Heads/Cam
By David Q in forum Internal EngineReplies: 18Last Post: 11-15-2009, 05:06 AM -
Trick Flow Heads and Cam Package
By BADASS2000SS in forum Internal EngineReplies: 127Last Post: 10-12-2008, 04:04 AM -
Trick Flow Heads and Cam Steetable?
By WS6ICK2K in forum Internal EngineReplies: 1Last Post: 06-04-2008, 07:02 AM -
trick flow heads and cam combo
By 1986camarojoe in forum Internal EngineReplies: 8Last Post: 09-08-2007, 02:07 PM
