Results 1 to 16 of 16
    Member Wyoming T/A's Avatar
    Powell,WY.
    1999 Trans AM 30th anniv.
    QUIZ--Identify this drive train
    Tempest?
    Greenville, NC
    Blue
    09 Nissan Altima
    so it's true, dinosaurs did exist!
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I'm thinkin classic Toronado.
    Powell,WY.
    Tempest?
    besides great pictures your pretty sharp--1962 pontiac tempest/lemans
    Quote Originally Posted by Wyoming T/A View Post
    I cheated.
    I looked at the url to the pics....
    Looks like Mr. Luos got it right--
    Per Wikipedia: "The Tempest's drivetrain employed an innovative tunnel that spanned almost the length of the car and housed a 3/4" flexible steel drive shaft running on bearings and riding inside a steel box, which forced it into a curve (colloquially dubbed "rope drive"), connecting the engine in the front to a unified differential and transmission in the rear. The combination of the rear-mounted transaxle and the front-mounted engine gave the car a weight distribution near an ideal 50/50 between the forward and rear wheels, enabled four-wheel independent suspension, and had the added benefit of eliminating the floor "hump" forward of the front seat needed to accommodate the transmission in conventional cars. The designer of this car was John Z. DeLorean, the division's chief engineer and a Packard veteran who would later become the division's head and still later famous for building cars bearing his own name. Since its Buick and Oldsmobile sister cars used a conventional Hotchkiss front engine and front transmission (both used a two-piece driveshaft to lower the hump) powertrain setup, the Tempest was truly unique. The Tempest was Motor Trend magazine's 1961 Car of the Year. Road & Track praised the Tempest as "exceptionally roomy" and "one of the very best utility cars since the Ford Model A.""
    A right answer is still a right answer.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    You should've showed the engine also. 1/2 of a 389 = 194.5 cid 4 cylinder.
    North Jersey
    2004 GTO M6
    The Tempest was small back then. I remember Tempests as the wide trackers like the 64 GTOs.
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    I cheated.
    Your Avatar is fuckin hilarious....
    Ontario, Canada
    yellow
    02 Collector Trans Am
    thats pretty bad ass
    Impwnded Smkn_TA's Avatar
    Davenport, Iowa
    Bright Red
    1999 Trans Am Ws6
    The driveshaft was only 3/4 of an inch? I could twist that in half with my dick.
    Powell,WY.
    how about a dash mounted shifter
    Tempest
    Davenport, Iowa
    Bright Red
    1999 Trans Am Ws6
    Torsion Tube driveshafts like that were actually put on trucks in the late 50's I think? Swear I seen something like that on Trucks once?
    Lots of old cars and trucks had the driveshaft running inside a tube. I think the Tempest was the only one that tried the "rope driveshaft" though.
  1. Help: Strange Vibrations and Noise from Drive Train
    By SMWS6TA in forum Drivetrain
    Last Post: 03-29-2010, 06:28 PM
  2. Do I need to beef up my drive train.
    By AKA Speedy in forum Drivetrain
    Last Post: 02-05-2010, 01:51 PM
  3. 99 Trans Am Part out *minus drive train*
    By JOHN_DEERE_LS6 in forum Parts For Sale / Trade
    Last Post: 03-03-2009, 10:26 AM
  4. GTO twin turbo vid - drive train testing.
    By peter@aps in forum Forced Induction
    Last Post: 03-11-2006, 09:20 AM
  5. drive train rattle/clunk
    By Trabots in forum Manual Transmission
    Last Post: 10-12-2005, 02:54 PM
