    houston
    Navy Blue
    ls1 trans am
    Angry Parking light housing keeps cracking.. leaking..
    The parking light housings keeps cracking on my 99 TA and it allows water to be retained, causing the lights to burn out. I have replaced the housing already. Has this happened to anyone else? Know a quick fix? I have tried silicone with no luck. Also what is the cheapest place to buy the housing (if only option). The cheapest I found was 30 shipped. Thanks guys
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    The BEST way to stop this, is buy new lenses, and use LED replacement bulbs (Available at Truck Stops...) The DRL's in these cars, utilize the Turn Filament in the PL assy, The Brightest one in the 2 filament bulb, thus creating Extreme Heat in this Tiny Light housing...Then you run thru a water puddle, or car wash... CRACK!!!.
    The LED's are WAY cooler in terms of operating temperature. As far as the "Fast Flash" issue u may incur, Get a variable load flasher.
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Lots of places online to order LED's
    houston
    Navy Blue
    ls1 trans am
    Makes sense... especially because they are always on. So the LED lights will fit into the stock sockets? or do I have to splice them into the existing wires? any links to the sites? Are the LED lights just as bright? On my Bike the LED turn signals are bright at night but hardly visible during a sunny day
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Sorry.....don't know a specific one
    http://www.google.com/search?q=autom...x=&startPage=1
    TEXAS... U mad?
    2K WS.6/ 2K9 G8GT
    Quote Originally Posted by JehalinTA View Post
    They make direct replacement bulbs, the are plug n play, and meet DOT requirements on brightness.
    In need of another LS1 00blacktransam112's Avatar
    Aug 2008
    Sutton MA
    2000 Pontiac TA
    I had the same problem minus the cracking. My bulb socket rusted to shit. i cut the old one out and put in a new one with weather-tite connectors in case the problem came back. i also drilled an 1/8" hole in the bottom of both housings so that the water that did get in there could drip out. it worked mint and no problems since then
    00 Trans Am:LS1-M6-SLP loudmouth 1-Lid-Bellows-CAI kit-85mm MAF-B&M ripper shifter-Torque Arm-LCA-Panhard Bar-STB-EGR AIR delete
    This winter: Torquer V.2-LS6 intake-LT's-Monster clutch-Custom y-pipe-and a really good tune
    Junior Member Circa307's Avatar
    Anderson sc
    98 Trans Am
    i had the same prob. with my 98. The filiment bulbs were actually blistering the inside of my housing and cracked mine also. I just ordered some on ebay like 5 min. ago and im planning to replace them with some LEDs. Theres no way im would put them hot @$$ bulbs into my brand new 30$ light housing. ill let you know how it comes out. Never thought of getting lights from a truck stop. good idea
  1. Parking light
    By Alex18 in forum Firebird / WS6
    Last Post: 01-16-2010, 08:15 PM
  2. Wanted: a 93-97 trans am fog light housing
    By MaxPlusTen in forum Parts Wanted / Trade
    Last Post: 12-30-2009, 06:40 AM
  3. Help: parking light?
    By LS1_ws6 in forum Firebird / WS6
    Last Post: 07-21-2009, 11:48 AM
  4. Run light housing
    By GOR1LA in forum Parts Wanted / Trade
    Last Post: 03-16-2009, 05:42 AM
  5. Parking light housing
    By Justin_98TA in forum Firebird / WS6
    Last Post: 02-15-2006, 10:27 AM
