Thread: axle removal
06-17-2009, 02:04 PM #1Junior Member
- Jun 2009
- fayetteville, nc
red- 2000 trans am ws6
axle removal
im a broke dik college student and i need to replace the wheel bearings in the rear. is there a link or images here that walks me through removing the axles? any and all help would be awesome!!!!
2000 ws6 6-speed had to put that so i dont look like an idiotLast edited by 910van; 06-17-2009 at 02:06 PM.
06-17-2009, 02:23 PM #2Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
06-17-2009, 02:37 PM #3Junior Member
- Jun 2009
- fayetteville, nc
is there one for doing wheel bearings? i cant get the damn c pins to come out, i cant get the shaft in far enough. i dont want to remove all of it for a wheel bearing. im a newbie and i cant afford a shop to do it, any more help would be awesome
06-17-2009, 03:07 PM #4
must be a 4 channel rear. sometimes the reluctor rings get in the way of pushing the axle in far enough to get the c-clips out. may have to do a little forcing of the axle inward. the only thing different you'll be doing as compared to swapping gears is you won't be removing the carrier. you'll pull the axle seal and then the axle bearings will come out.
06-17-2009, 04:13 PM #5
Unbolt the abs sensors from the brake backing plate and then the axles will go in far enough for the c clip to out.
06-18-2009, 11:35 AM #6Junior Member
- Jun 2009
- fayetteville, nc
Thanks alot guys!! got the bearings in, rides smooth but there is still a noise from the rear. sounds a little like metal on metal. not as loud as before. i had the axles checked where it sits on the bearings, didnt seem to have any scores or gouges in it. are there any more bearings, near the spider gear? and if so, is it a beech to replace like this one was? neways, thanks a bunch guys. ill be posting pics of the car soon.
2000 WS6 127000 mi
SLP Intake
SLP Loudmouth
Rest is stock as can be!
06-18-2009, 11:47 AM #7
the are four more. two on the carrier and two on the pinion gear
06-18-2009, 01:38 PM #8
Are you sure the rotors aren't touching the calipers, pads or brackets? Does the noise change when you turn, brake, etc.? Nothing touching the drive shaft? Yoke flange not touching the rear?
06-20-2009, 08:00 PM #9Junior Member
- Jun 2009
- fayetteville, nc
ive checked clearance for everything and the noise goes away under acceleration, and screams to high heavens if u let off in gear. little clunk in the rear when the clutch is pressed, and its every gear under and off acceleration. i dunno, maybe just look for a better rear end. any suggestions? thanks for all the help here guys!!
SLP axle back VS Borla axle back
By DVrec21 in forum External EngineReplies: 13Last Post: 01-05-2011, 03:45 AM -
Axle removal
By Bottesini in forum DrivetrainReplies: 1Last Post: 12-16-2008, 11:42 AM -
axle
By 02ws6trans in forum DrivetrainReplies: 2Last Post: 08-20-2008, 04:15 PM -
installation and removal of rear axle
By 01ws6tablk in forum Suspension and HandlingReplies: 3Last Post: 05-01-2008, 06:39 PM -
Under or over the axle?
By M-Ten in forum External EngineReplies: 20Last Post: 01-10-2008, 06:46 AM
