Results 1 to 20 of 25
    Member cmb570's Avatar
    Jun 2006
    Fort Mill, SC
    Question Strano Spring users in here...plz
    I got my Strano springs and konis installed and love them. Only thing I wouldnt mind changing is the ride height of the front. Wondering if anyone else has done anything to lower front a little. I was wondering if its possible to cut part of the rubber isolator (top of spring) to lower ride height. What about lower control arms ?
    cutting spring is not an option
    Jun 2006
    Fort Mill, SC
    Are you already sitting on the lower spring perch of the Koni's?
    Jun 2006
    Fort Mill, SC
    I didnt see any adjustments on the lower springs perch. Im sitting right on spring perch. The perch looked like it was stuck in current spot, non-adjustable
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Quote Originally Posted by cmb570 View Post
    The rront shocks have a dual groove (for the C clip) for a spring perch change, this changes the ride height. They should have came out of the box on the top groove. it's NOT reccomended to use Strano Springs (or any spring for that matter) on the lower perch setting because you can damage the shock.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    Which Koni's?
    Got a part number?
    Jun 2006
    Fort Mill, SC
    I have the 4/3 konis from strano. I didnt touch the original perch settings on the shocks. In the front my car (floor to fender) sits 27" high, slightly less in back
    You can use the lower perch on the front shocks. You need to remove the spring from the shock, and change the perch location. Should drop the front a little extra for you.
    Jun 2006
    Fort Mill, SC
    i didnt see a way to lower the perch. looked like it was stuck on the groove. Wonder if theres a document or picture on how to do this
    Jun 2006
    Fort Mill, SC
    damn, looks like I need to tear it down and find a how to lower perch
    Part #: Koni 4/3
    Brand: Koni
    Price: $732.00
    --2 spring perch positions (stock or approx. 3/4" lower)
    --Direct replacement for OEM
    --Huge handling improvement, superior body motion control with less roll rate generation
    --Firm ride quality without being harsh
    --Externally adjustable/on car rebound adjustment on the front, Internal rebound/off car adjustment on the rear shocks.
    --The best shock for performance applications and/or lowering springs
    --Rebuildable and Revalveable for custom setups
    --Also known as “Koni Yellows”
    --Lifetime Warranty
    Should be pretty easy once the spring is removed from the shock.
    The perch location is basicly just a groove in the shock. There are two, only can see one because the perch is in the other one.
    I have been tempted to actually sell the Strano springs, use the lower perch on the Koni's up front, and do the heater hose mod to the rear. Still drop the car a little for style and probably hook up a bit better at the track.
    Undertaker During the Day SpinsB's Avatar
    Cincinnati
    2001 Pontiac WS6 427ci
    Koni 4/4 & strano springs here I was told using the lower perch was not good for the shock with this set up?
    2001 WS6 LS2 427ci Forged Callie Crank, Billet Steel Compstar Connecting Rods, Forged Aluminum Wiseco Ceramic Coated Pistons, Stage III Ported & Polished Racing LS1 Cylinder Heads, F.A.S.T. 90/90, TTS LT's, GMMG exhaust, Spec stage III clutch, 18/19 iForged Aero's, Koni 4/4 Strano Springs.
    Jun 2006
    Fort Mill, SC
    is there a trick to lower perch to bottom grove
    Jun 2006
    Fort Mill, SC
    welll installing on lower perch leveled out my ride. Thanks guys for the help
    Member Joe00SS's Avatar
    CT
    White Liquid Silver
    2000 Camaro SS/ 02 YZF-R1
    do you feel a difference in ride since you changed it? I'm about to get this setup, just waiting on stock to come in.
    Any pics?
    Jun 2006
    Fort Mill, SC
    I think it feels like front is more settle and secure, but it could just be me. Not real good with camera so here are a couple new pictures
    Member WARP211's Avatar
    Feb 2007
    FairField, CA
    RED 35TH ANIVERSARY PKG
    2002 CAMARO SS 35th LE
    [QUOTE=cmb570;1974423]I think it feels like front is more settle and secure, but it could just be me. Not real good with camera so here are a couple new pictures
    Click for full size[/QUOTE
    Its looking good just enough.... Looks like a 2 finger gap in there.. I like it..
    CT
    White Liquid Silver
    Wow that looks excellent! I can't wait
    Cincinnati
    I was told by Sam that its not recommended to use the lower perch as it can cause the shock to bottom out....... Have you had any issues with this?
    Jun 2006
    Fort Mill, SC
    Quote Originally Posted by SpinsB View Post
    No I havent had any issues with front shock bottom out. Its only a 1.4 " if that. However Sam does know what he is talking about, but I like the look and it rides nice so.....letting it ride
  1. MD, PA, NY, NJ, VA, OH, DE ...... E85, E98 Users chime in...
    By midatlanticspeed in forum Drag Racing
    Last Post: 08-08-2012, 07:17 PM
  2. Wanted: strano lowering spring
    By Blackbird WS6 in forum Parts Wanted / Trade
    Last Post: 09-10-2010, 07:02 PM
  3. Droid X users
    By chiller2484 in forum Almost Anything Goes
    Last Post: 08-18-2010, 03:25 PM
  4. Hello LS1.com and all users...
    By Luis Grayeb in forum New Member Introductions
    Last Post: 04-03-2008, 03:16 PM
  5. Magnaflow users please
    By chevyvette1 in forum Firebird / WS6
    Last Post: 11-22-2006, 05:24 PM
