Page 1 of 3 123 LastLast
Results 1 to 20 of 45
    Jun 2009
    nashville Tn
    1999 camaro
    all new sound system
    okay so im getting all new speakers and radio. i am thinking about getting an alpine HU and 4 alpine type R's to replace the door pannel speakers and the rear seat speakers. i was wondering do i need a amp or can they jus power off the HU. and if i do could i tap into the old monsoon amp or would i have to get another amp.
    Any help would be great!
    -thanks!
    Junior Member lilpb1's Avatar
    Long Beach, Cali
    I have Alpine all around and they sound good.
    Jun 2009
    nashville Tn
    1999 camaro
    yeaa thats what im getting to! did you have to gut the monsoon? or did u just replace the monsoon speakers with them?
    The Coffee Shop
    Red Jewel
    2010 SS
    Alpine is a good choice for the money.....
    Member 02WS6dream's Avatar
    Jun 2006
    Charlotte, NC
    2001 Trans Am WS6
    could go either way. if you do alpine all around but keep monsoon amp then sound quality will be similar to stock... biggest improvement you can make is upgrade amp. you would be better off spending money to replace monsoon amp and keep stock speakers then to replace speakers and keep stock amp. Replace both and you will be very happy . most distortion originates in amp--speakers simply reproduce it and get burnt up by it. Most speakers get "blown" by being underpowered--not over as most people logically assume. Its just like upgrading motor/powertrain. it all works together. you don't realize the potential of one component until you compliment it with matching components. upgrade just the amp or all at the same time. my .02
    Jun 2009
    nashville Tn
    1999 camaro
    alright then thats what im gonna buy next then!...any good suggestions on what kind of amp i should get?
    The Coffee Shop
    Red Jewel
    2010 SS
    How many and what size speakers are you going to buy? Also, are you going to run active or passive? Oh yea, Budget?
    Central Florida
    2000 Z28
    The Alpine PDX-5 is a tiny 5 channel 50x4 + 300x1 if you're going to be adding a sub. The only caveat is that it has to be mounted parallel to the floor for the cooling system or else Alpine voids the warranty. Alot of folks who have them mount them under seats but I don't know if the floor contour of the F-Body's will allow that.
    You can also check out the MTX JackHammer JH805. It's bigger and it's printed wattage rating is lower than the Alpine, but most MTX amps put out quite a bit more power than advertised. It's internally fan cooled so you can mount it wherever there is room. It's crossover is a little more flexible than the Alpine as well. You can run front + rear + sub or high + mid + low as the rear channel has a HP and LP control.
    The Coffee Shop
    Red Jewel
    2010 SS
    Quote Originally Posted by tremiles View Post
    FYI......The PDX-5 puts out 75W x 4 plus the sub channel
    Central Florida
    2000 Z28
    You're right, I don't know where I got 50. Their real-world 14.4v wattage is even higher too.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I would never run one amp to power mids, highs, and a sub..just my opinion.
    I have always had one amp for the mids and highs and another amp to power subs. MTX is a good quality amplifier. Each individual amp is tested and the rated output is noted on the amp. Well it used to be at least.
    Jun 2009
    nashville Tn
    1999 camaro
    Smile
    Quote Originally Posted by The Project View Post
    i am planning on buy to 6.5 inch alpine r's and redo the system....and what do u mean my active and passive? im still kinda new to this stuff...and i really dont mind spending a good amount of money on my car as long as it sounds good!
    The Coffee Shop
    Red Jewel
    2010 SS
    Quote Originally Posted by Camaro998 View Post
    In an active system the wire path is as follows...
    Head Unit - xover - Amp - Speakers
    Passive is as follows...
    Head Unit - Amp - Xover - Speakers
    Basically passive is just plug in play where active allows you to tune the system more. Most people simply go for the passive set up. However you will gain better sound quality out of your speakers by going active. If you are a car audio novice I would suggest passive and see how the system sounds. Also with an active set-up, you need one power source for each speaker. If you bought a 6.5" comp set you would need a 4 channel amp (since you have 4 speakers). If you go passive you could get away with a 2 channel amp (and wire the tweeter and mid together).
    Heere is a link that explains it in more detail
    http://www.caraudio.com/forum/showthread.php?t=146726
    Jun 2009
    nashville Tn
    1999 camaro
    aight yea i think i might go with active then...how much more exspensive is it to go with active?
    The Coffee Shop
    Red Jewel
    2010 SS
    All it would cost is a little bit more wiring and maybe some "tuning time" at the stereo shop. What you could do is have the xovers near the amps (if the amps are in the back), this would reduce the amount of wiring used. If you run active and have the amps in the back and xovers near the front comp sets you would need a lot more wiring to run the active setup.
    Best to draw the system out on paper and get a feel for where everything will go and how much wiring is involved.
    The xovers are designed to be used in an active or passive setup so there is no extra cost there.
    Central Florida
    2000 Z28
    Most decent amplifiers today come with a high pass filter/xover, low pass or both. So free. You don't necessarily need a stand-alone xover unless the xover in the amp doesn't meet your needs.
    Junior Member CamaroSS354's Avatar
    Jun 2009
    Columbia, SC
    2002 Monte Carlo SS
    i have alpine type r components in my car and i highly suggest the alpine pdx 4.100 or 4.150 depending on what you wanna spend
    Agree
    Member Blue28's Avatar
    Ca.
    Navy Blue
    1999 Camaro Z28
    For now get a 50-100 watt rms 4 channel amp!
    What's you budget for a Amp?
    A JL Audio 300/4 is a good Amp for the money, that's if you buy it online!
    jefferson city
    green
    1994 camaro
    im running 2 10" MTX jackhammers in my camaro powered by the MTX jackhammer amp for that size and it is unbelievable! i won second in the audio division of my hometowns biggest car show and then i realized my bass boost on the amp was set to zero. novice move right?? lmfao so i tuned it to max (12) and couldn't turn the stereo up all the way. so i cut it back down to mid (6) and im pleased beyond belief.
    bottom line. i would go with the jackhammer amp from experience. and if you really don't mind spending money and want an ungodly loud system i would spring for a set of the 10" or 12" subs. just my opinion
  1. new sound system in TA
    By ls1ws6ben in forum Stereo and Electronics
    Last Post: 03-01-2011, 02:42 PM
  2. Help: want new sound system for the fastcar
    By luvmyz28 in forum Stereo and Electronics
    Last Post: 11-12-2009, 12:55 PM
  3. Help: Sound system diagrams
    By cz28mdn in forum Stereo and Electronics
    Last Post: 01-23-2009, 01:19 AM
  4. Question: Installing sound system
    By supersport00 in forum Stereo and Electronics
    Last Post: 07-29-2008, 06:44 PM
  5. Pioneer Sound System
    By asm72ecko in forum Parts For Sale / Trade
    Last Post: 05-04-2006, 06:07 PM
