Thread: lt1 brake upgrade to ls1
06-13-2009, 07:17 PM #1
if from lt1 to ls1 brake swap is a direct swap, then from lt1 to c5 a direct swap, or am i missing something?
06-13-2009, 07:47 PM #2
want to know before i go by the junkyard
06-14-2009, 03:52 PM #3
can i get some help please
06-14-2009, 04:24 PM #4
gotta switch out the backing plates
06-15-2009, 10:14 PM #5
what if i go ls1 front and c5 rear
06-16-2009, 12:07 PM #6
Rear's are tuffer than fronts because the mount is welded to the axle tube. For front lt1 to LS1 swap you need:
left and right ls1 spindles with or with out hubs, lt1 hubs will bolt into ls1 spindles.
left and right LS1 callipers and pads
2 front LS1 rotors
left and right ls1 brake lines
A C5 front caliper is almost the exact same as an LS1. the only differance is the LS1 has the cooling webs cut down to fit in a 16 inch tire, were the C5 will fit in only a 17 inch wheel or higher.
I did the LS1 conversion with sloted and drilled rotors and wow what a differance over the lt1 stockers. You can get most of this stuff off E-bay or alot of parts stores sell remand ls1 callipers.
C5 or C6 brake upgrade
By cuzimoto in forum General Help - 5th GenReplies: 10Last Post: 12-22-2013, 01:45 PM -
C6 ZO6 Brake upgrade on a C5?
By NIKDSC5 in forum CorvetteReplies: 4Last Post: 01-21-2008, 09:06 AM -
possible brake upgrade?
By third_shift|studios in forum Suspension and HandlingReplies: 13Last Post: 11-12-2007, 04:56 PM -
Brake upgrade
By Naf in forum GTOReplies: 10Last Post: 03-27-2007, 09:18 PM -
Brake upgrade for 97
By toplessHO in forum Suspension and HandlingReplies: 5Last Post: 12-09-2006, 04:42 AM
