Results 1 to 13 of 13
Thread: Synchros?
06-12-2009, 10:18 AM #1
- Mar 2006
- Ohio - West of Cleveland
Light Metallic Pewter- 1999 Camaro Z28
Synchros?
Ok, so my clutch finally went out last year and I decided to wait till spring to get her fixed (since I was going to store it during the winter anyway). The master cylinder is what actually went out. I took the time to scout out a shop that I felt would do a good job. I found a shop called (extreme performance in North Olmstead, OH) I had the car fixed there and a whole new clutch put in since they said that the pressure plate was getting pretty burnt up. I had a "Zoom" clutch put in (the one made of kevlar) to the tune of $1700. Anyway I got it back and now it slips out of second gear. This is so utterly annoying that it makes me not want to drive my most valuable posession any more I took it back and they said that it was the synchros and that they couldn't possibly have done that. I don't know that much about it, but I've been told the synchros go out when the car has been driven hard. I need advice on what to do PLEEEEASE!!
06-12-2009, 06:15 PM #2
- Apr 2008
- Madison, WI
do you have a stock shifter or aftermarket?
It could be a syncro or a bent shift fork. If they drove it hard and really yanked it down into second HARD, they could bend the Aluminum shift fork.
06-13-2009, 04:35 PM #3
- Mar 2006
If they bent the shift fork would I have to have the tranny pulled? I would have to have the tranny pulled to replace the synchros right?
06-13-2009, 06:09 PM #4
- Apr 2008
- Madison, WI
yes to both q's
06-27-2009, 08:08 PM #5
Could you explain what the heck a synhros are and the aluminum shift forks???
-Aaron
Mods: SLP Flowpac Cold Air Induction Package, 160 Thermo, TB bypass, SLP (Clutch, Pressure Plate, Flywhell), Skip Shift Elminator, UMI (SFC, Tower Brace, LCA, Torque Arm, Panhand Bar), no cats, Moser 9" w/ 3.89 gears, 5.0 short throw, Strano Springs, Koni single adj, '94 OEM ZR-1 wheels
06-28-2009, 01:45 PM #6
06-28-2009, 04:58 PM #7
- Apr 2008
- Madison, WI
I'm not completely sure, but I think all the T56 shift forks are aluminum but the 1-2 is a little beefier and usually doesn't cause a problem.
06-29-2009, 01:22 PM #8
06-30-2009, 07:56 PM #9
HiPo, you are correct. 1-2 shift forks are steel. 3-4 are aluminum, which is why these are more prone to bending.
07-01-2009, 03:31 AM #10
- Apr 2008
- Madison, WI
35th-ANV-SS, are you sure?
EPP's website says:
"1-2 shift fork - There is no replacement for the 1-2 shift fork. It is aluminum and is fairly strong by design."
07-01-2009, 08:00 AM #11
Cutlass, no! Haha. I thought I had read what I posted in the T56 service manual, but now that I think about it, it was from a thread in either here or LS1tech. My statement was incorrect. You are correct. 1-2 shift forks and 3-4 shift forks are all aluminum.
http://www.transmissiondigest.com/te...tds%20HTML.htm
07-01-2009, 12:49 PM #12
Ok, so you are saying here, most do not have issues with the 1-2 fork correct? My T56 was rebuilt with a STEEL 3-4 fork and viper shafts. Thats the only reason im questioning it. I cant remember which of the two were the problems childs.
So, judging by EPP's site, the 1-2 fork is aluminum, and a decently strong piece. The 3-4 fork, is a weak link and is the fork that gets replaced during a T56 upgrade.
Right?
07-01-2009, 03:23 PM #13
That sounds right to me R. I remember reading that, and that is why I had thought what I did originally. From what I remember and have seen as T56 upgrade parts...3-4 forks are always swapped with steel ones, among other things.
Question: transmission synchros
By SMWS6TA in forum Manual TransmissionReplies: 12Last Post: 08-17-2010, 02:00 PM -
Synchros or Hydraulics?
By 01ws6er in forum Manual TransmissionReplies: 4Last Post: 06-22-2010, 03:03 AM
