Thread: Upgrades
06-12-2009, 04:38 AM #1Junior Member
- Jun 2009
- md
Upgrades
Needing i
06-12-2009, 05:28 AM #2
I'd go with a Intake manifold, bigger TB, Better heads. Vortech.
P.S. Great pass time, thumbs up.
06-12-2009, 08:33 AM #3Junior Member
- Jun 2009
- md
Thanks for the input, anyone else have any ideas?
06-12-2009, 09:11 AM #4
You can buy a good set of heads, a better cam (any specs on your cam??), cutout, weight reduction, fast intake and throttle body, 90mm, 92mm, or 100mm, your choice. I think they make all those sizes now. What tires you using?
With suspension work, cam only cars with bolt-ons can make it in the 11s easy.
Then there is always the posibility of nitrous, s/c, or turbo.
06-12-2009, 09:39 AM #5Junior Member
- Jun 2009
- md
does
06-12-2009, 10:26 AM #6
Usually people wait to add an aftermarket "FAST" intake until they do heads. You will still see gains, typically like 15-25rwhp with the setup you have. The gains are much higher after you get a good set of heads or are using forced induction like a supercharger or a turbo.
A tire I use is a Nitto 555 R, they are great for a bolt-on car or cam only car. I use a 315mm wide Nitto 555 R. They do great on the street, last longer than most drag radials and are some what driveable in the rain.
There are a lot of popular tires out there to use, and you can find traction with these, but obviously a slick or M/T drag radial might be better, they are a bit better traction wise but don't last very long. The BFG drag radial is about the same way, but they last like 3-5k miles if you are lucky.
You have to let us know what you intend to use the car for. Daily driver, street warrior, weekend warrior, or all drag strip?
06-12-2009, 10:28 AM #7
Oh, i hope your tranny, clutch, and rear end can handle more power and stickier tires. If not, save up extra money for when they break...mod away man!
06-12-2009, 10:37 AM #8Junior Member
- Jun 2009
- md
Thanks.
06-12-2009, 12:56 PM #9
There are plenty of choices for heads out there and i don't know much about heads, but they can add quite a bit of hp if matched correctly with your cam. Add that "FAST" intake/tb combo and you can touch upper 400rwhp.
Help: upgrades
By 2000dreambird in forum External EngineReplies: 1Last Post: 05-31-2011, 09:46 PM -
Question: 97 lt1 upgrades
By RollingD in forum LT1Replies: 25Last Post: 08-28-2009, 07:49 PM -
Possible new upgrades
By [email protected] in forum Firebird / WS6Replies: 4Last Post: 08-31-2008, 11:28 AM -
Upgrades
By joker in forum Firebird / WS6Replies: 9Last Post: 09-13-2007, 05:00 PM
