Results 1 to 15 of 15
    Junior Member silverjess's Avatar
    Minnesota
    2000 WS6
    Where To By Clutch Master Cylinder
    Looks like I need a clutch master, I changed the fluid, still no change. Where can a I get a quality master? I don't need a high performance one, I'm on a tight budget right now. Thanks for the input.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    The GM one isn't too badly priced from one of our sponsors - GMPartsDirect.com. Its listed at $140
    Minnesota
    2000 WS6
    Thanks, I've seen them as low as $80.00 at different "off brand sites", would one of those suffice?
    Madison, WI
    2001 Silverado Z71
    yes probablly
    Member raysz28's Avatar
    Central Ohio
    Ticket Red
    M6 1998 Z-28
    I just got the one from AdvanceAuto i think it was only 75 bucks. it works great! just make sure to get the whole system bled.
    Minnesota
    2000 WS6
    Sounds good, thanks a bunch.......I'm wondering though if its the slave or the master?? My problem is when holding the clutch in, it won't keep the gears from engaging. The pedal will then become "dead", unless pumped a few times? Thanks again.
    Central Ohio
    Ticket Red
    M6 1998 Z-28
    i ended up replacing both...
    here is my old slave,
    notice all the black gunk around the end of the bearing.
    here is the new slave. notice the difference,
    Also, my master was very sloppy. once i removed it, i could push the cylinder in and out and here/feel that it did not seal at the top. thus allowing air to enter the system, which added one more reason for the trans to not disengage...
    if you are going to remove the trans anyway to get the slave out, i recommend checking your pilot bushing. i had my clutch done about 2-3 years ago and had them put a pilot bearing in instead of a bushing, thinking it would be better. below is the picture of my bushing in my hand...
    apparently they will fail for several reasons. 1, they are not able to be lubricated once installed, and 2 they can be installed wrong very easily. so go with a bushing instead L :-)
    Minnesota
    2000 WS6
    Thanks for the info, I'll be tearing into it next week......
    Junior Member DesertRat's Avatar
    May 2008
    Brooklyn, NY
    1998 Camaro Z28 conv'
    Quote Originally Posted by raysz28 View Post
    here is my old slave, Click for full size
    here is the new slave. notice the difference, Click for full size
    if you are going to remove the trans anyway to get the slave out, i recommend checking your pilot bushing. i had my clutch done about 2-3 years ago and had them put a pilot bearing in instead of a bushing, thinking it would be better. below is the picture of my bushing in my hand...Click for full size
    Thanks for the great info I was about to install one of dose GM needle roller pilot bearing as an upgrade to the bronze pilot bushing but after watching your pic's i will stick with the stock bushings!!!
    By the way do you know if the Ram high flow Slave Cylinder and throwout bearing assembly for 98-02 LS1 F-body is a better unit then the stock GM unit? Again thanks for the write up
    Central Ohio
    Ticket Red
    M6 1998 Z-28
    Quote Originally Posted by DesertRat View Post
    unless you are getting a huge clutch that needs all that adjustable stuff, i wouldnt bother...
    May 2008
    Brooklyn, NY
    Thanks.
    Minnesota
    2000 WS6
    So there's really no way to tell which one is bad with no leaks?
    Central Ohio
    Ticket Red
    M6 1998 Z-28
    Central Ohio
    Ticket Red
    M6 1998 Z-28
    Also, i found this clutch care web site...i have started doing this as well.
    http://www.rangeracceleration.com/Clutch_Care.html
    Member WARP211's Avatar
    Feb 2007
    FairField, CA
    RED 35TH ANIVERSARY PKG
    2002 CAMARO SS 35th LE
    That piot bearing you have in your hand looks like a stock pilot bearing instead of a bushing that you said it was... So is that a bearing or a bushing in your hand?
  1. Question: clutch master cylinder
    By 1MileCrash in forum Manual Transmission
    Last Post: 03-30-2012, 09:40 AM
  2. WTB: Clutch Master Cylinder
    By Black02LS1 in forum Western Members
    Last Post: 10-25-2008, 10:05 AM
  3. GM Clutch Master Cylinder
    By rc74racer in forum Drivetrain
    Last Post: 09-02-2007, 08:38 AM
  4. new GM clutch master cylinder kit
    By sammy burks in forum Parts Wanted / Trade
    Last Post: 04-28-2007, 10:37 AM
  5. Master Cylinder or Clutch?
    By ERICV82GO in forum Manual Transmission
    Last Post: 01-04-2007, 09:39 AM
