Results 1 to 3 of 3
Thread: i need starter help asap!!!!!
06-11-2009, 05:20 AM #1
ok maybe this is a dumd question but i am at a complete loss on how to get the old starter out and the new one in. i disconnected all the wiring to the starter. i removed the flywheel cover to give me a little more clearence i jacked up the tranny its self alittle but everything i try is blocked by the lines to the tranny cooler, which i really dont want to remove. do i have to? is there another way? please help!!!
06-11-2009, 01:43 PM #2
I am guessing you have stock manifolds and exhaust pipes?
Not sure about removing it with stock exhaust but you might try pushing it out through the top. LT1 engines were such a bad service design. The trans lines should be cliped at the bottom side of the block and near the middle. they just pop out of that clip if that gives you any room.
06-11-2009, 05:07 PM #3
- Feb 2006
- Orange County, NY
I have a M6 but I was able to maneuver the starter by the pipes to get it out. If you dropped the y-pipe I am sure it is 100x easier. Not sure if you could move the tranny lines enough to get it out. Luckily it is half the size of a gen 1 starter and several pounds lighter.
Help: starter
By dzikusnj in forum Firebird / WS6Replies: 5Last Post: 06-23-2014, 08:48 AM -
it is the starter right?
By jondev in forum External EngineReplies: 7Last Post: 09-29-2008, 02:48 AM -
WTB....starter
By 1tonzr2 in forum Parts Wanted / TradeReplies: 0Last Post: 03-11-2007, 07:02 PM -
Bad Starter??
By Wikid NaSSty in forum General HelpReplies: 8Last Post: 09-25-2006, 09:59 PM -
WTB LS1 starter
By lowonair6173 in forum Parts Wanted / TradeReplies: 0Last Post: 03-20-2006, 04:35 PM
