Results 1 to 20 of 27
Thread: One Bald Tire
    Just a farmboy V8MUSCLE's Avatar
    Montpelier, VA
    2000 Pontiac Trans Am
    One Bald Tire
    So... Bought 4 new tires Michelin pilot sports. rotated every month, balanced every other month. went to rotate today and found that my drivers side rear tire is bald. all the other tires are fine, about a quarter inch left of tread left on all the other tires. its worn like it was over inflated, but it was low, 28psi. any ideas what could cause this. i dont remember it being close to bald, or even to the indicators.
    Montpelier, VA
    ive put about 25k on em.
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    limited slip diff? broken? thats all i can really think of...
    Montpelier, VA
    it has just started making a brushing/slight grinding noise. its sounds more like something rubbing than anything else. ill pop the cover and change the fluid tomorrow and see if i see anything.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Your differential is going out or you have a bearing going out causing the tire to have excess wear. Now would be a good time to see to it before something handgrenades.
    Montpelier, VA
    differential looks fine. had a few metal shavings on the magnet, but no chunks in the bottom or obvious cracks/worn teeth. checked the wheel bearings and they are still fine.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Check your pass rear caliper. It may be sticking. My last car did that. Was FWD. Left front was OK but the RF tire was bald and I noticed the RF would spin from a stop. Turned out my LF caliper was frozen causing all the power to go to the RF and wear out the RF tire.
    Montpelier, VA
    what would be the best way to tell if a caliper is sticking?
    North Jersey
    2004 GTO M6
    Put the car on a lift in neutral. Once in the air, spin either rear wheel. If one is difficult, or won't turn at all, there ya go. Stuck caliper.
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by V8MUSCLE View Post
    carefully feel the center of each wheel right after a drive.....if the one wheel is hot, or even much warmer than the other then jack it up and do the spin test.
    if its really sticking bad the wheel will get very hot and you might even have blueing on the rotor
    Montpelier, VA
    alright, last night i poped the cover off and checked everything out in there. this morning when i went out i found a second gasket. is there supposed to be 2 gaskets between the cover and case, or just 1.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    one gasket
    Montpelier, VA
    awesome, well it didnt leak with two, and it isnt leaking with 1 so i guess im good. the fluid i drained smelt like ASS... and was green.
    North Jersey
    2004 GTO M6
    Did you do the spin test yet?
    Montpelier, VA
    spun from the tire and driveshaft. didnt see anything cracked/worn. the ujoint did have a little play though.
    i didnt have a sticking caliper, both tires spun freely. i put my second worst tire on the back and am just going to burn em up. im going to get an alignment at school in the fall.
    mercersburg pa
    hugger orange
    2004
    hopefully the alignment will take care of it. when you swap tires, look at your rear tie rods just to be sure its not loose or bent
    Madison, WI
    2001 Silverado Z71
    he doesn't have rear tie rod ends
    Beaver Dam KY
    79 T/A -91 Firebird
    Yup solid axle.
    Bent axle housing ??????
    mercersburg pa
    hugger orange
    2004
    lol opps I was thinking GTO irs, not F-body
    Montpelier, VA
    i didnt see any damage to the axel housing anywhere. i guess ill find out if its bent if the other tire shreds soon. if its bent i guess its time for a new 9"
  1. Bald Eagle
    By LimeNine in forum Almost Anything Goes
    Last Post: 09-17-2013, 09:35 PM
  2. Wasting bald tire
    Last Post: 06-04-2012, 02:46 AM
  3. inner part of tire getting bald
    By stangslayer98 in forum Wheels and Tires
    Last Post: 05-22-2008, 04:58 AM
  4. bald 315 BFG DR's
    By Orange SS in forum Parts For Sale / Trade
    Last Post: 08-22-2005, 01:12 PM
