Results 1 to 20 of 23
Thread: Air Fuel Ratio at WOT
06-08-2009, 06:52 AM #1Junior Member
- May 2007
- Buffalo
Orange- 1999 Camaro
Guys,
If there is a such thing...what do you think the "danger zone" for the air fuel ratio is for running too lean at WOT?
06-08-2009, 08:16 AM #2
For a naturally aspirated engine???
For a safe tune I shoot for 12.6-12.8 You can squeak out a few more HP with 12.9-13.0 but if you get much higher than that it's a bit risky. I prefer to give up a few HP and stay on the safe side, especially if running pump gas.
Every engine is a bit different in where they make the best power. I use the track and MPH along with the wideband to see what the engine likes on a given day.
06-08-2009, 06:46 PM #3Senior Member
- May 2009
- Toronto
SOM- 2002 SS
12.8 is a good afr. Any higher and it really isnt worth the risk especially for any car that is driven any more than at the track.
06-11-2009, 05:14 PM #4LS1.com Sponsor
- Apr 2006
- san antonio
silver- 94 silv
Next time you have a completely stock truck/car slap the wideband on it and notice how long GM keeps the a/f ratio at 14.7:1.
On the trucks it's worse!
When we dyno trucks here, the entire dyno pull is at 14.7:1.
With GM's fuel delays based on RPM, time and torque, you'd think these engines would break more often than they do, but you'd be surprised.
I'm sure they have their reasons.
Like the guys said above, 12.5 to 13.0 is optimal. If you use a dyno to dial in your a/f ratio, be sure to check it at the track in real world driving conditions.
good luck,
allen
06-12-2009, 02:11 AM #5
06-12-2009, 08:53 AM #6
They delay PE fueling for highway/towing economy. As you guessed, the timing they run is very low by comparison to the cars.
06-12-2009, 12:08 PM #7Just a farmboy
- Jun 2007
- Montpelier, VA
Pewter- 2000 Pontiac Trans Am
i thought you wanted 14.7ish?
06-12-2009, 01:36 PM #8
06-12-2009, 02:49 PM #9Just a farmboy
- Jun 2007
- Montpelier, VA
i see said the blind man...
06-12-2009, 04:11 PM #10
06-24-2009, 04:26 AM #11
how do you read the a/f mixture
i have a predator hand held can i read it with this ?
if not what all do i need,ill get it.
never mind did some reading going to get this
http://www.lethalperformance.com/98-...t-blue-p-18823Last edited by lovedrvr; 06-24-2009 at 04:52 AM.
06-24-2009, 05:45 AM #12
06-24-2009, 08:27 AM #13
I use the LM-1 so I can move it from car to car.
06-24-2009, 08:49 AM #14
06-24-2009, 08:53 AM #15
06-24-2009, 09:01 AM #16
06-24-2009, 09:29 AM #17
06-27-2009, 11:40 PM #18
07-07-2009, 03:33 AM #19
I feel anything over 13.50 is pushing your luck....
07-07-2009, 03:08 PM #20
Air Fuel Ratio Question
By SMWS6TA in forum General HelpReplies: 19Last Post: 02-02-2017, 11:55 AM -
ideal Air-fuel ratio
By bigbucks39 in forum Computer & TuningReplies: 1Last Post: 04-21-2008, 08:07 AM -
Fuel/Racing Fuel Ratio
By Whiteboycntdnce in forum General HelpReplies: 3Last Post: 11-22-2007, 05:27 AM -
air fuel ratio gauge
By coupe00 in forum Camaro / SSReplies: 8Last Post: 02-14-2007, 01:27 AM -
Air / Fuel Ratio Gauges....HELP
By SSNAKEATER23 in forum Computer & TuningReplies: 3Last Post: 02-22-2006, 05:22 AM
