Results 1 to 20 of 26
Thread: brake job ?
06-06-2009, 11:09 AM #1
- Sep 2008
- Atlanta, GA,Ft.Walton Bch,FL
- Blog Entries
- 1
silver- 99 ws6
brake job ?
I'm planning a rear brake job rotors & pads.
? before I remove the caliptors can I remove the brake fluid resover lid
then use a large screwdriver to force the old pads in to make room for the new thicker pads?
or must I use a large C-clamp to force the caliptor piston in?
I did a search.
Thanks
06-06-2009, 11:20 AM #2
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
C-Clamp is the way to go unless you buy the "tool" for it, which does the exact same thing for 2wice the cost...
C-Clamps can be had new a Vato Zone for less than $10...
just be sure to back it up with the old pad, and dont push directly on the piston.
06-06-2009, 11:28 AM #3
leave the lid on - just loosen it, and make sure the master is not too full, I always put a few rags around it in case fluid overflows.
there are several ways to "retract" the caliper piston bu a C clamp is recommended so you don't "cock" the piston and possibly score the caliper.
Remember to release the emergency brake when you get the wheels off or the rotor isn't coming off!
Take your time and jump back here to ask if you run into questions along the way.
06-06-2009, 11:31 AM #4
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
c-clamp
OK I'll spend a few bucks on the big C-clamp.
I have also been told that the ten year old brake fluid will be fine to leave in was told brake fluid does'nt break down like motor oil?
ThanksLast edited by qwik219d9; 06-06-2009 at 11:33 AM.
06-06-2009, 11:47 AM #5
06-06-2009, 11:52 AM #6
- Sep 2005
- TEXAS... U mad?
If it aint black, leave it alone. Other wise, you'll spend all day trying to bleed the air back outta the system.
06-06-2009, 12:18 PM #7
One of the important chracteristics of brake fluid is to expel moisture. That capability breaks down over time. If you have the time and really want to "do it right", then definitely change the fluid, it will help all the other parts to last longer.
06-06-2009, 03:34 PM #8
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
One thing I do is one brake at a time. Than one you have one all together again just pump the brakes a few times and you will not have to really worry about the fluid overflowing.
06-06-2009, 04:03 PM #9
- Oct 2007
- Beaver Dam KY
The brake tool is 10 bucks at autozone with the knob. I broke the knob and smacked a 13mm socket on the end with a hammer so I can use air tools to compress the pistons
While your in there you can adjust the rear ebrake as well.
06-06-2009, 04:42 PM #10
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
This is why it's important to keep the resivoir filled.....you won't get air unless you allow the fluid to get too low.
Suck old fluid out with turkey baster, re-fill with fresh, bleed about 3 to 4 times, re-fill....repeat until clean fluid comes out, move to next wheel.
Simple.
06-07-2009, 02:40 AM #11
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
turkey bastor
sounds like I got some boguy advice w/ the big screw driver and leaving the ten year old fluid in.
I'm glad I have a helpfull resouce here at LS1.com
I was thinking of the Turkey bastor method priced one at the Dallor store for $1. Looks like I'll need an assistant to pump the brakes.
? on bleeding one man pumps where to buy and how much?
This will be my first complete brake job just wanting to CMA.
Thanks
06-07-2009, 02:42 AM #12
- Oct 2007
- Beaver Dam KY
06-07-2009, 04:47 AM #13
- Apr 2008
- Madison, WI
You can probably use a big screwdriver to pry the piston back while the caliper is still bolted on the rearend. Just pry in between the pad and the rotor.
06-07-2009, 07:05 PM #14
- Jun 2008
- Decatur Al
NBM- 99 Z28
06-07-2009, 07:18 PM #15
- Oct 2007
- Beaver Dam KY
06-07-2009, 08:13 PM #16
Get a piece of scrap metal to put over the pistons and then use the c-clamp on the middle of that. Thats how i did it.
06-07-2009, 09:15 PM #17
- Sep 2006
- Ontario Canada
Black- 2001 Camaro ss
..anyone know the "dot" value on a stock 01 ss..mine is still the original..car has 17000 miles..since new..may service brakes this summer..I have a slight pulsation in the front when brakes get really hot..at some point I'll replace front pads, front rotors, then check rears..what is the wear ratio front to back..how many miles can you expect out of a factory ss model pads and rotors..i live in northern climate..heat is not a real issue here..thanks for any suggestions and replys..P.S. seen an 2010 camaro ss at local dealer..them silver ones look hot..but happy with my 01 for now
06-07-2009, 10:11 PM #18
- Sep 2005
- TEXAS... U mad?
DOT 3..... should say on the Reservoir lid
06-07-2009, 10:12 PM #19
06-07-2009, 11:27 PM #20
- Oct 2007
- Beaver Dam KY
http://www.usrallyteam.com/index.php...roducts_id=529
Ill throw this out here too. Many people think these tools are expensive.. The right tool for the right job will save you a headache, time and money in the end
Parking Brake "Brake" light not turning on
By Questioner in forum Firebird / WS6Replies: 1Last Post: 11-05-2015, 06:52 AM -
Wilwood C5 Big Brake Kit - Brake Check!
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 04-18-2011, 03:20 PM -
Corvette Brake Rotors - Give Me A Brake
By Ed Blown Vert in forum CorvetteReplies: 1Last Post: 09-17-2010, 03:39 PM -
Brake Pad Technology - What's New In Brake Pads
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 02-01-2010, 09:10 AM -
Pontiac Drum Brake Drag Reduction - Low-Drag Brake
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 05-04-2009, 05:40 AM
