06-04-2009, 07:58 PM #1Junior Member
- Feb 2006
- Hurricane, WV
Red- 1998 Trans Am
Switching from Automatic to Six Speed
I have a 98 T/A with the 4L60e automatic transmission. I ran across a Six Speed out of a 97 WS6 T/A. It comes with the pedals and maybe the shifter. It has 41K miles. He's asking $800.00...is this a fair price? I'll have to buy a clutch and flywheel.
Will the swap work? Will I need a different computer? What about the drive shaft, is it the same?, what else needs done??
My car is a nice one...it's fun to drive even though it is an automatic. If I do this swap will it be as fast a T/A that came with a six speed? Will it fit in there and look stock? (I know I might have to change the console too)
Any ideas?
Thanks!
06-05-2009, 09:27 AM #2
I think you will need to cut open the tunnel and remove the auto braket and get a 6 speed consol. PCM I'm not sure about but more than likely. No reason it wouldn't run like a factory car as long as the PCM is setup for the 6 speed and you have a good gear out back.
What rear gears do you have?
06-05-2009, 09:43 AM #3
an LT1 6 speed wont work with an LS1 unless you get an adapter i think or might not work at all different hydraulic set up.
06-05-2009, 03:35 PM #4
I think it had something to do with the input shaft had to be changed
06-05-2009, 03:44 PM #5
Sounds like a headache in the making.
I think I would consider trading for a factory 6 speed if you really want to go that way.
06-15-2009, 04:54 PM #6
sell your a4 and look for an M6
high speed automatic!?
By Faught in forum Multimedia SectionReplies: 0Last Post: 06-01-2011, 09:38 AM -
Question: Automatic Swap out for 6 speed???
By tlurkws6 in forum Automatic TransmissionReplies: 12Last Post: 09-01-2009, 06:10 PM -
Question: Switching from mass air to speed density?Problems?
By LS1nterceptor in forum Computer & TuningReplies: 3Last Post: 09-16-2008, 10:30 AM -
01 ss automatic to six speed?
By sunsetorangess in forum General HelpReplies: 5Last Post: 01-27-2006, 08:24 PM -
automatic to 6 speed
By musclecam in forum DrivetrainReplies: 2Last Post: 11-23-2005, 02:23 PM
