    Member ssgtcarroll's Avatar
    East Prospect, PA
    91RS 99Z28 11GT 86Bronco
    ATV Electrical help!
    Ok ATV forums suck when it comes to getting help.
    Gonna try you gearheads. I need fresh minds on this I am stumped.
    ATV is a Honda 1987 Fourtrax TRX200.
    Getting NO spark.
    First thing I did was throw a plug in. Its the same plug as factory gaped to factory spec. .28
    No spark....
    So I stick my voltmeter on the high tension coard (spark plug wire) to ground....nothing.
    Attach the meter + to the black/white wire going into the coil and the - on the coil terminal the wire connects to. Hit the starter button, I get 30+ volts. So I replace the coil.
    Still no spark.
    Now mind you starter and lights work. Bike ran AWESOME day before I had no spark.
    I am thinking CDI box. Stator tested ok on resistances as repair manual states.
    Any idea guys before I buy a 100$ cdi box?
    Does the coil need a curtain amount of volts before it hits the plug?
    East Prospect, PA
    Just did some more searching. Looks like coil requires 100+ volts into it. And the Stator needs to put out 100+
    Guess if the stator doesnt put out 100+ its the stator...if it does put out +100 then its the CDI box?
    Plus theres like 5 wires comming out of the stator...which one I test....these damn manuals suck.
    Please chime in.
    I feel your pain. Good luck on this. I just went through it with the boat. No spark. Does the bike have a kill switch and have you tested the switch? Mined ended up being a short.
    nj
    90 Mustang 5.0
    cdi boxes go bad on those old hondas. its very unlikely something like a stator goes bad, normally theres a contact problem if anything
    Feb 2008
    Palm Beach, FL
    440 RWHP / 410 TQ
    2000 SLP CAMARO SS
    Most likely CDI! Try to find a used one on eBay for half the price!
  1. Electrical?
    By karpetcm in forum General Help
    Last Post: 04-17-2011, 12:15 AM
  2. Help Electrical...
    By ra84y in forum General Help
    Last Post: 07-19-2010, 06:36 PM
  3. electrical?
    By stangnightmare in forum General Help
    Last Post: 03-05-2007, 12:58 PM
  4. Electrical HELP!!! PLEASE
    By TimC in forum General Help
    Last Post: 05-26-2006, 08:39 AM
  5. Electrical Help
    By dlcully in forum General Help
    Last Post: 05-02-2006, 11:20 AM
