    Senior Member Ramairgod84's Avatar
    Aug 2008
    peoria, az
    2001 WS6
    sway bar size help
    Hey guys I was wondering if anyone knows the stock size of the c5 sway bars, and then what size the zo6 bars are. I'm lookin to upgrade and people keep tellin me to go with the zo6 instead of hotchkis
    Aug 2000
    Indy
    scroll down, more info than you'll want.
    http://forums.corvetteforum.com/c5-g...ngths-etc.html
    04 C5 A4 Torch Red - sold
    2009 CTS4 Ice Black - sold
    2013 1500 Silverado Z71 - sold
    02 Z/28 M6 Onyx Black All Options - Sold
    2014 Caddy CTS4 - DD
    2016 Silverado 2500HD
    2020 Caddy XT6
    2020 2SS Vert
    Aug 2008
    peoria, az
    2001 WS6
    lol it doesnt say what the stock size is in mm tho.
    Aug 2000
    Indy
    incorrect, here this will help
    C5 Suspension
    Brake Rotor Dimensions-front
    3 cm, 2 mm --- rotor thickness --- Source
    7 cm --- center hole diameter --- Source
    7 cm --- lug to lug spacing --- Source
    11 cm --- lug diameter...don't know how to say from two lugs across rotor to single lug. Imagine an acute triangle if dots were connected --- Source
    3 cm, 8 mm --- inside face of hub to rotor surface --- Source
    19 cm --- inner hub diameter --- Source
    21 cm, 7 mm --- out hub diameter --- Source
    32 cm, 5 mm --- rotor diameter --- Source
    Brake Rotor Dimensions-rear -- dimensions that are same as front are not repeated
    2 cm, 6 mm --- rotor thickness --- Source
    4 cm, 2 mm --- inside face of hub to rotor surface --- Source
    20 cm, 2 mm --- out hub diameter --- Source
    30 cm, 5 mm --- rotor diameter --- Source
    Caliper Pistons
    1-9/16" dia x 2 pistons per caliper = 3.835 sq inches --- Front Pistons --- Source
    1-3/4" dia x 1 piston per caliper = 2.405 sq inches --- Rear Piston --- Source
    Swaybars
    23mm, front; 19.1mm, rear --- FE1/Base --- Source
    25.4mm, front; 21.7mm, rear --- FE3/Z51 97-99 --- Source
    28.6mm, front; 23.6mm, rear --- FE3/Z51 00-04 --- Source
    30.0mm, front; 23.6mm, rear --- FE4/Z06 --- Source
    31.75mm, front; 25.4mm, rear --- Hotchkis --- Source
    38.4mm, front; 27.5mm, rear --- GM T1 --- Source
    Spring Rates
    439.66 lb/in, front; 576.70 lb/in, rear (manual trans); 588.12 lb/in, rear (auto trans) --- FE-1/Base --- Source
    440 lb/in, front; 577 lb/in, rear --- FE-1/Base --- Source
    457 lb/in, front; 577 lb/in, rear --- MSRC --- Source
    525 lb/in, front --- FE-3/Z51 --- Source
    660 lb/in, front --- FE-3/Z51 --- Source
    327 lb/in, rear --- FE-3/Z51 --- Source
    633 lb/in, rear --- FE-3/Z51 --- Source
    634 lb/in, rear --- FE-3/Z51 --- Source
    525.31 lb/in, front; 633.80 lb/in, rear (manual trans); 645.22 lb/in, rear (auto trans) --- FE-3/Z51 --- Source
    525 lb/in, front; 634 lb/in, rear --- FE-3/Z51 --- Source
    620 lb/in, rear --- FE-4/Z06 --- Source
    650 lb/in, front; 680 lb/in, rear --- FE-4/Z06 --- Source
    525 lb/in, front; 714 lb/in, rear --- FE-4/Z06 --- Source
    650 lb/in, front; 800 lb/in, rear --- T1 --- Source
    1,000 lb/in, front; 680 lb/in, rear --- Danny Popp's setup --- Source
    77 N/mm --- FE1 & F45 front suspension spring rate --- SAE SP-1282
    1.15 Hz --- FE1 & F45 front suspension ride frequency --- SAE SP-1282
    103 N/mm --- FE1 & F45 rear suspension spring rate --- SAE SP-1282
    1.36 Hz --- FE1 & F45 rear suspension ride frequency --- SAE SP-1282
    1.18 --- FE1 & F45 Ride frequency ratio --- SAE SP-1282
    93 N/mm --- FE3 front suspension spring rate --- SAE SP-1282
    1.20 Hz --- FE3 front suspension ride frequency --- SAE SP-1282
    113 N/mm --- FE3 rear suspension spring rate --- SAE SP-1282
    1.45 Hz --- FE3 rear suspension ride frequency --- SAE SP-1282
    1.21 --- FE3 Ride frequency ratio --- SAE SP-1282
    Misc Suspension
    36mm --- FE-1/Base shock absorber piston --- SAE SP-1282
    45mm --- FE-3/Z51 shock absorber piston --- SAE SP-1282
    aluminum --- front upper control arm bushing bar pin material --- SAE SP-1282
    aluminum --- rear uppper control arm bushing inner metals --- SAE SP-1282
    glass reinforced resin --- early stabilizer end links --- SAE SP-1282
    AA6061-T6 (forged) --- front upper control arm material --- SAE SP-1282
    A356-T6 (hybrid cast preform-forging) --- front lower control arm material --- SAE SP-1282
    A356-T6 (hybrid cast preform-forging) --- rear upper control arm material --- SAE SP-1282
    A356-T6 (hybrid cast preform-forging) --- rear lower control arm material --- SAE SP-1282
    A356-T6 (hybrid cast preform-forging) --- knuckles (all are from the same casting) --- SAE SP-1282
    Control Arm Notes
    Front lower, and upper/lower control arms are an L-shape variation. The forward leg of the control arm is set near to wheel center. The forward leg of the lower control arms is fitted with a "handling" bushing; the rear leg is fitted with a "ride" bushing. The "ride" bushing absorbs the brunt of road deflections while the "handling" bushing absorbs the brunt of the cornering forces. The "handling" bushing is 3-6 times stiffer than the "ride" bushing.
    C5 Alignment
    6.5° --- front caster angle --- SAE SP-1282
    0.2° --- rear caster angle --- SAE SP-1282
    36mm --- front caster trail --- SAE SP-1282
    63mm --- front spindle length --- SAE SP-1282
    50.7mm --- rear spindle length --- SAE SP-1282
    8.8° --- front kingpin angle --- SAE SP-1282
    9.2° --- rear kingpin angle (inclination) --- SAE SP-1282
    10mm --- front scrub radius --- SAE SP-1282
    1.0mm --- rear scrub radius --- SAE SP-1282
    1.34:1 --- front shock lever arm ratio --- SAE SP-1282
    1.43:1 --- rear shock lever arm ratio --- SAE SP-1282
    5.2 --- rear side-view swing arm angle --- SAE SP-1282
    C4 Alignment
    5.9° --- front caster angle --- SAE SP-1282
    1.2° --- rear caster angle --- SAE SP-1282
    45mm --- front caster trail --- SAE SP-1282
    93mm --- front spindle length --- SAE SP-1282
    123.0mm --- rear spindle length --- SAE SP-1282
    16° --- front kingpin angle --- SAE SP-1282
    -7.1° --- rear kingpin angle (inclination) --- SAE SP-1282
    162.3mm --- rear scrub radius --- SAE SP-1282
    7.8 --- rear side-view swing arm angle --- SAE SP-1282
    Chassis
    720 N-mm/deg (>10X roll couple distribution) --- Static stiffness --- SAE SP-1282
    23 Hz (separation from suspension tramp mode) --- Structural 1st torsional mode --- SAE SP-1282
    16 Hz --- Suspension tramp frequency --- SAE SP-1282
    21 Hz (separation from suspension hop mode) --- Structural 1st bending mode --- SAE SP-1282
    15 Hz --- Suspension hop frequency --- SAE SP-1282
    20 dB separation from mount --- Input mobility --- SAE SP-1282
    Chassis Notes
    The cored composite floorboards increased 1st structural torsion mode by 0.1-0.2 Hz. The tunnel closeout (aka tunnel plate) increased 1st structure torsion mode by ~2 Hz. It makes sense that stronger tunnel plates stiffen the chassis. The C6 Z06 has carbon fiber floorboards to reduce weight, but possibly stiffen the chassis as well. The boards behind the seats often flex and pop on convertibles, and I believe stiffer boards would further increase chassis stiffness.
    OEM Wheel specs
    8.5"x17", front; 9.5"x18", rear --- 97-99 Wagon wheels --- Source
    8.5"x17", offset=58mm, front; 9.5"x18", offset=65mm, rear --- 00-04 Thin/Thick 5-spoke wheels --- Source, Source
    9.5"x17", front; 10.5"x18", rear --- 01-04 Z06 forged or cast wheels --- Source
    17"x11", offset=50mm, rear --- AFS GS --- Source, Source=http://forums.corvetteforum.com/showthread.php?t=448185]Source[/url]
    OEM Tire specs
    P245/45ZR17, front; P275/40ZR18, rear --- Goodyear Eagle F1 GS --- SAE SP-1282
    Alignment
    Autocross
    CAMBER: -2.5° front, -1.5° rear; CASTER: max; TOE: -1/8" toe-out, front; 1/8" toe-in, rear --- Source
    C5 Service Manual Alignment --- Source
    Front Individual Toe +0.04 degree
    Front Sum Toe +0.08 degree
    Front Individual Caster +6.9 degree
    Front Cross Caster within 0.50 degree
    Front Individual Camber -0.20 degree
    Front Cross Camber within 0.50 degree
    Rear Individual Toe -0.01 degree
    Rear Sum Toe -0.02 degree
    Rear Individual Camber -0.18 degree
    Rear Cross Camber within 0.50 degree
    Z06 Service Manual Alignment --- Source
    LEFT & RIGHT FRONT:
    Camber: Specified Range: -1.2 to -0.2 Optimal: -0.7
    Caster: Specified Range: 6.4 to 7.4 Optimal 6.9
    Toe: Specified Range: 0.15 to 0.25 Optimal 0.20
    FRONT
    Cross Camber: Specified Range: -0.5 to 0.5 Optimal: 0.0
    Cross Caster: Specified Range: -0.5 to 0.5 Optimal: 0.0
    Total Toe: Specified Range: 0.30 to 0.50 Optimal: 0.40
    LEFT & RIGHT REAR
    Toe: Specified Range: -0.06 to 0.05 Optimal: -0.005
    REAR
    Total Toe: Specified Range: -0.11 to 0.09 Optimal: -0.01
    Thrust Angle: Specified Range: -0.10 to 0.10 Optimal: 0.00
    Z06 (missing in '01) Service Manual Alignment - as written by Hib Halverson, but same as above --- Source
    Front Individual Toe: +0.04 degree +/- 0.10 degree
    Front Sum Toe : +0.08 degree +/- 0.20 degree
    Front Individual Caster: +6.9 degree +/- 0.50 degree
    Front Cross Caster: within +/- 0.25 degree
    Front Individual Camber: -0.70 degree +/-0.50 degree
    Front Cross Camber: within +/-0.25 degree
    Rear Individual Toe: -0.01 degree +/- 0.10 degree
    Rear Sum Toe: -0.02 degree +/- 0.20 degree
    Rear Individual Camber: -0.68 degree +/- 0.50 degree
    Rear Cross Camber: within +/- 0.50 degree
    Chassis
    0.080" before hydroforming, 0.071" after hydroforming --- C5 frame rail wall thickness --- Source
    55mm --- Stock driveshaft diameter, part #12561082 --- Source
    63mm --- Stock driveshaft diameter, part #12564457 --- Source
    2 1/2" --- LG carbon fiber driveshaft --- Source
    Transmission
  1. 98 Z/28 Sway bar size?
    By LETHALxLS1 in forum Suspension and Handling
    Last Post: 02-25-2013, 07:25 AM
  2. sway bar bushing size?
    By patriot1136 in forum Suspension and Handling
    Last Post: 11-08-2009, 10:04 AM
  3. sway bar bushing size?????
    By MotorDogStar in forum Suspension and Handling
    Last Post: 08-04-2009, 12:44 PM
  4. Question: Sway Bar Size?
    By kool-aide in forum Suspension and Handling
    Last Post: 08-10-2008, 07:31 AM
  5. SS Sway Bar Size?
    By x10-wakerider in forum Suspension and Handling
    Last Post: 08-07-2006, 10:02 PM
