Thread: rough ride
05-31-2009, 04:06 PM #1
rough ride
so about a year or so ago i lowered my car with eibach pro kit and left the stock shocks. after about a month of driving, i couldn't take the shock shocks any more. so i put on bilstein heavy duty shocks. made the ride tons better, but still my ride is rough. now i know you all are just gonna ram these strano springs and koni shocks down my throat, but at this point, with as little as i drive the car im not looking to do that. i will def consider new shocks, but the spings are staying. so my question is, will upgrading the shocks help out any more? the car just seems to hit every bump sooo hard. also, would an adjustable panhard rod help out at all? or any other suggestions? thanks guys
05-31-2009, 05:15 PM #2
an adjustable panhard rod will not make it ride any softer. it's all in the shocks. you need a shock with a softer rate of compression. this is where a set of adjustable shocks come into use. you can tailor it to how you want it to feel. QA1 single adjustable is a good place to start. i think Koni has a 3 way adjustable.
05-31-2009, 05:43 PM #3
something like this? im not looking to spend $1200 on shocks
http://store.summitracing.com/partde...5&autoview=sku
or these?
http://store.summitracing.com/partde...5&autoview=skuLast edited by mpfranks; 05-31-2009 at 05:50 PM.
05-31-2009, 06:03 PM #4
both of those are for the rear, but yes those.
05-31-2009, 06:06 PM #5
05-31-2009, 06:07 PM #6
also, being lowered you might be hitting the bumpstops. this will make for a rough feel as well. before buying shocks, trying trimming them.
05-31-2009, 06:10 PM #7
06-01-2009, 07:54 AM #8Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
With the lower springs all shocks are going to let the suspension hit the bumpstops. It's the nature of the beast you lower the car so your closer to the bumpstop. What you need is something that has a better compression setting so your not hitting them so hard.
Also keep in mind that tire pressure can have a dramatic effect on the ride esp. on impact harshness.Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
06-01-2009, 01:09 PM #9
is modifying the bumpstops gonna do anything to help it? and i run 30-32psi in my tires. i wonder if calling summit and complaining about the bilsteins would help, maybe they will refund the money towards a set of something else. the front feels fine, its just the damn rear is like riding on square tires.
06-02-2009, 09:46 AM #10Firebird Encyclopedia
- Oct 2006
Shortening the bumpstop would work but it's not reccomended considering you may damage the shock during compression. It's really a band aid fix anyway. I think Strano still sells his Spec Bilstiens that have a different valve setting in the rear. This may be what your looking for, but it would be best to call him as see what his opinion is.
I personally have Sams Springs, Swaybars and Koni 4/4's.
I believe Koni's may solve your issue but I'm not going to ram it down your throat that you need to buy them.
It's my understanding that the Bilstien HD's are better suited for stock springs with their softer rate. Your Eibach rears are progressive rate and will need a different valve setting. I believe the shocks I originally mentioned may solve the issue.
Good luckLast edited by 9T8W66; 06-02-2009 at 01:52 PM.
06-02-2009, 11:26 AM #11
06-02-2009, 11:49 AM #12
i see airbags
Rough Ride
By therel82 in forum Suspension and HandlingReplies: 3Last Post: 08-04-2009, 09:32 AM -
I need advise with my rough ride
By JayTA98 in forum Suspension and HandlingReplies: 6Last Post: 06-17-2009, 04:59 AM -
Question: rough ride
By phoenix05 in forum Firebird / WS6Replies: 9Last Post: 03-20-2009, 03:27 AM -
rough ride
By egod in forum Suspension and HandlingReplies: 20Last Post: 11-11-2008, 07:18 AM -
Rough Ride after install....
By TransAm11973 in forum General HelpReplies: 6Last Post: 01-09-2008, 07:39 AM
