Thread: 95 Bird Quits Running
05-29-2009, 03:04 PM #1
- May 2009
- canada
blue green- 1995 Trans Am
Need Some Input, I have a 95 Trans Am, Lt1, 6 speed.93mm thottle body, bbk headers. and it has run fine up till now: It will start fine run for about 2 minutes then quit, then it is hard to restart, but it will resart, might do this a few times, but as soon as the service engine light comes on it runs fine, had it read and I have replaced TPS, Mass Air, and O2 sensors, and it still does the same thing, noticed the last time that when the service light comes on both cooling fans are running flat out, even when the engine is cold. it doesen't seem to matter if it is cold or warmed up it does it every time you start it.any help or suggestions would be gratefully accepted.
05-29-2009, 04:13 PM #2
fuel pump?? have you noticed any lack of power?
05-29-2009, 04:58 PM #3
- May 2009
- canada
No lack of power, fuel pump test was good
05-29-2009, 05:04 PM #4
id have to say spark then? what are the codes you are throwing, go to autozone and they will scan for free.
05-31-2009, 06:44 PM #5
- Apr 2008
- Southlake, TX
Red- 2002 T/A
ive had the spark plug problem before, really annoying to fix lol
05-31-2009, 11:56 PM #6
could be the temp sensor as that would be the only thing to cause the fans to come on asides the AC from being on. Best idea I can think of.
06-02-2009, 08:42 AM #7
- May 2009
- canada
Thanks people, replaced the opti, seems to have cured the problem for now lol
Sen Boxer calls it quits
By SMWS6TA in forum Political / Debate ForumReplies: 4Last Post: 01-09-2015, 08:26 AM -
93 firebird quits running, dies, going down the road
By tom123 in forum LT1Replies: 4Last Post: 07-29-2013, 11:03 AM -
2000 Z windows and radio quits
By pafuller in forum General HelpReplies: 20Last Post: 11-23-2010, 02:24 PM -
quits running on top end
By whiskers in forum Internal EngineReplies: 10Last Post: 05-01-2010, 12:13 PM -
Anyone running a big hood bird?
By StuntmanMike in forum Firebird / WS6Replies: 44Last Post: 10-29-2007, 06:29 PM
