Results 1 to 20 of 20
Thread: Driver Side Power Window
05-26-2009, 12:07 PM #1Junior Member
- Oct 2008
- Monroe,Michigan
Silver- 2000 TA LS1 A4w/ShiftKit
My drivers side window has all of a sudden had a mind of its own. It will roll up sometimes. It will roll down sometimes. Sometimes it will stop rolling up or down and after I drive for a bit or turn the car on or off it will then roll up and down partially again. Sometimes it seems slow and sometimes it is normal. But rarely can I get it to roll completly up or down. Has anyone ever had this happen to them before and have any insight for me ? Is it a motor issue or could it possibly be in addition to a grounding issue that I am having with my drivers side parking light and passenger rear brake/running lights ?
05-26-2009, 12:45 PM #2Impounded
- Oct 2007
- Beaver Dam KY
BCM Needs soldering.
http://ls1tech.com/forums/general-ls...blems-fix.html
05-26-2009, 01:43 PM #3Junior Member
- Oct 2008
- Monroe,Michigan
I am not having any problems with my radio its jus my drivers window and my parking lights. Do u still think it has something to do with my BCM ?
05-27-2009, 01:57 AM #4Impounded
- Oct 2007
- Beaver Dam KY
05-28-2009, 05:07 AM #5Senior Member
- Apr 2008
- Madison, WI
I gave some bad info so I deleted this post
05-28-2009, 07:03 PM #6Junior Member
- Oct 2008
- Monroe,Michigan
No it dont roll up and down by itself. What I am trying to say is that when I press down 2 roll the window down it will go down a couple of inches then stop and wont go up or down until after a lil while of driving or sitting then it will move a few more inches when I press the button. Sometimes I will get lucky and it will completly roll down or up while I am holding the the switch down or up. Its crazy I read in another thread that it could be the motor or the switch. I just dont want to go tearn into nething I dont have to. It is jus that I am having a electrical nightmare lately with this car. The parking lights are acting up the rear running lights are acting up now the window is. Before that I had to replace my headlight motor and I have seen some crazy codes pop up on my Moonsoon radio screen. It looks like a bunch of Jibbirish
05-28-2009, 07:04 PM #7Junior Member
- Oct 2008
- Monroe,Michigan
http://www.ls1.com/forums/showthread.php?t=8307
This was the link I am referring 2 in my last post.
05-28-2009, 07:28 PM #8Senior Member
- Apr 2008
- Madison, WI
I retract my previous statement about the windows/BCM relationship. The BCM powers up the 'Power Windows' circuit breaker, so there is a possbility there. But since this only seems to be affecting the driver's window and sometimes it works ok, I think you have a switch problem.
05-29-2009, 09:27 PM #9Junior Member
- Oct 2008
- Monroe,Michigan
I bought a new switch today and installed it. Its still acting up so that eliminates the switch problem. Thanks for the info though. It was pretty easy to install and I can return it to AutoZone. No biggie. So now i get to get into the dreaded motor replacement but first I think I am going to pull the BCM and check that out.
05-29-2009, 09:38 PM #10Impounded
- Oct 2007
- Beaver Dam KY
05-30-2009, 05:45 AM #11Junior Member
- Oct 2008
- Monroe,Michigan
Will do. Not a problem. I hope it is something easy as that. Where would be a good place to pick up a solder gun ?
05-30-2009, 07:32 AM #12
05-30-2009, 02:39 PM #13Junior Member
- Oct 2008
- Monroe,Michigan
Thanks again. I appreciate all the great info from u guys.
05-30-2009, 02:41 PM #14Impounded
- Oct 2007
- Beaver Dam KY
06-10-2009, 09:30 PM #15Junior Member
- Nov 2008
- Seattle
Pewter- 1999 Trans Am
In my case (just tonight) it was the window motor.
06-11-2009, 03:29 PM #16Member
- Nov 2005
- allenhurst GA
onyx black- 1999 formula firebird
i have already replaced my d/s power window motor and am going to do the passengerside..but i thought i read somewhere that they are actually underpowered and that is why the motors go out so fast on em..that and they are a PITA to get to with ogre mitts....
06-11-2009, 03:37 PM #17
06-11-2009, 07:54 PM #18Impounded
- Oct 2007
- Beaver Dam KY
06-12-2009, 03:57 AM #19
06-12-2009, 03:58 AM #20Impounded
- Oct 2007
- Beaver Dam KY
Wanted: Driver's side power window/door lock switch for a Camaro
By White Knight in forum Parts Wanted / TradeReplies: 0Last Post: 02-05-2012, 01:16 AM -
Wanted: Driver side power window/ mirror switch bezel.
By bluefields88 in forum Parts Wanted / TradeReplies: 0Last Post: 10-25-2011, 10:40 PM -
Wanted: Fbody Driver Side Power Window Motor
By Zaccagnini in forum Parts Wanted / TradeReplies: 2Last Post: 10-23-2008, 01:23 AM -
Driver Side Window????????????
By 02sunsetorangess in forum Camaro / SSReplies: 4Last Post: 11-08-2005, 01:24 PM -
driver side window
By sscrazy in forum General HelpReplies: 3Last Post: 09-11-2005, 03:08 PM
Tell that to the landfill,lol. I threw it away as soon as I got done with the project.lol Oh well live and learn I guess.
