05-25-2009, 10:41 AM #1Senior Member
- May 2009
- Toronto
SOM- 2002 SS
How to adjust adj' Panhard bar after lowering???
Is there any links to how this is done or does this need to be done at an alignment shoppe ? Just lowered the car and will be ordering a bar any day now. Which way does the axle go when lowered?
05-25-2009, 11:06 AM #2Slow'er'Ass
- Thornton, CO
It all depends on the lowering kit.
Basicly just line the tires up under the car is all I did.
05-25-2009, 12:11 PM #3Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
The rear is going to swing to the left, so to recenter it you need to shorten the bar.
Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
05-27-2009, 05:18 PM #4Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
How to adjust?
By silverWS6 in forum Suspension and HandlingReplies: 5Last Post: 02-07-2011, 08:48 PM -
Help: How to set or adjust LCA's
By TerribleTed in forum Suspension and HandlingReplies: 4Last Post: 08-09-2010, 09:14 AM -
How to adjust panhard bar?
By Frankthetank in forum Suspension and HandlingReplies: 1Last Post: 08-02-2008, 02:54 AM -
just installed lowering kit, need to adjust pinion angle?
By got-a-ls1 in forum Suspension and HandlingReplies: 8Last Post: 04-08-2007, 06:27 PM -
How to install/adjust and ajustable panhard rod?
By Warbird in forum Suspension and HandlingReplies: 2Last Post: 12-24-2005, 12:57 PM
