Results 1 to 20 of 27
Thread: Seafoam
    Junior Member David Ray's Avatar
    Lake City, Fl.
    Onyx Black
    2001 Camaro Z28
    Seafoam
    I just ran about half a bottle of seafoam in my '01 Z28. I checked the oil color several times...it changed gradually to a dark brown...and when I got close to a hundred and fifty miles (over a three day period) I changed the oil filter (Bosch Pemium) and let out about three quarts of oil/seafoam (synthetic RP) and replaced it with convential oil (Pennzoil High Mileage). I thought this would help supple any seals or rubber internals.I didn't drain out all of the treated synthetic because the oil was really dirty and I want to filter the oil with the new filter and keep cleaning the insides. I figure I'm going to keep watching the dipstick and then change everything again in about three more days. Does that sound like a good plan? My Z28 has over a 100K miles on it, but it runs strong and fast. Will I hurt the motor by leaving the diluted seafoam in a little while longer 'cause I think it needs a little more cleaning before I rinse fully.
    Retired Outlaw Sum Bitch
    No you wont hurt anything you havent already damaged under the scenario you described. In the future get away from solvents.
    This is what you want... http://www.auto-rx.com/
    I would be remiss if I failed to say Royal Purple is one of the worst performing oils on the market.
    Lake City, Fl.
    Onyx Black
    2001 Camaro Z28
    Should I hadn't done it? Should I just drain it all now?
    Lake City, Fl.
    Onyx Black
    2001 Camaro Z28
    I forgot to add that I only had the RP in for about three weeks before I did this. I want to eventually get to Pennzoil Platinum 5-30. Do you like that better bossman/Sarge.
    I dont care what anybody runs frankly. I just post the facts backed up with data so folks can make an informed decision. Seafoam is solvents. Solvents eat seals/gaskets and take awhile to get off the metal surfaces thus not allowing lubricants to properly lube.
    in my Trans Am
    2000 Trans Am WS6
    i was waiting for this....
    Stang Killer TransAmFanatic's Avatar
    Feb 2008
    Harvey, La
    1999 Trans Am
    gonna buy some of that and try it?
    in my Trans Am
    2000 Trans Am WS6
    no i mean i was waiting for sarge to chime in and say exactly what he did...
    Lake City, Fl.
    Onyx Black
    2001 Camaro Z28
    How do I rinse the stuff out thoroughly, I don't want it in there if it is doing damage. I've heard good stuff about it. What about running it through the brake booster hose? I've read alot of conflicting opinions about it. I just want to clean my motor and see if she keeps running strong. If my car gets me about five thousand miles with no major issues I want to upgrade the top end. Anybody think I could have damaged somethng by using the seafoam?
    Seafoam is a solvent. That is all we had back in the day. Today we have lanolin ester based cleaners that clean better and are "soft" cleaners versus "hard" cleaners like Seafoam. But Seafoam enjoys bunch of old guys saying it is the best because that is all we had in the day so folks still buy it today. AutoRX is a 3000 mile clean phase and a 3000 mile rinse phase. When you are done your motor is one clean sum bitch. But it slowly and totally dissolves carbon/coke/varnish and deposits it to your oil filter.
    And no to keep the fueling system up to par I use 2 stroke TC-W3 at 500:1 mix.
    http://www.ls1.com/forums/showthread.php?t=91206
    I know a lot of people get good results from SeaFoam. Sure they do it is a harsh solvent. But there is better solutions than SeaFoam for sure that clean better and do no harm.
    I would get me a SuperTech filter and SuperTech oil from WalMart and run that stuff about an hour driving around. Then drain and replace filter/oil with your favorite lubes.
    Junior Member speedingfish's Avatar
    Dec 2008
    Olympia
    pewter
    2000 ss
    How does the Sarge like Lucas oil additive?
    When I Seafoam....
    1/3 can in the oil a week before oil change.
    1/3 can into the fuel.
    1/3 can into the brake booster.
    I change the oil (all of it) a week after I put in Seafoam. I also do the brake booster Seafoam before the oil change.
    Sarge knows much more about the 'ingredients' of Seafoam, but as I understand it, it is a lubricant of some sort. Not arguing with him, as he is probably right and I am just rattling off shit I heard online.
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    subscribed.
    When I Seafoam....
    SeaFoam is a solvent not a lubricant. Think paint thinner.
    Listen up guys....Even SeaFoam themselves tells you not to run it over 100 miles in your motor oil for a reason!! It is eating the crap out of your internals and thinning your oil to a 10 weight.
    Sure you "feel" a cleaner engine running smoother. Clean motor runs better. But I'll be damned if I am going to use solvents to clean my motor.
    Long story short....here is about 40% of the ingredients of SeaFoam....
    20-15% isopropyl (rubbing) alcohol, and 20-5% naptha (Coleman camp stove fuel).
    Knock yourself out
    By the way...the rest of it is just simple mineral oil. Think 10 weight baby oil.
    Quote Originally Posted by speedingfish View Post
    Bout as much as getting my wisdom teeth removed with no pain killers. All it has is viscosity enhancers. Thickeners. That's it.
    Here it is...total worthless VI and that is all....
    Lucas Virgin Analysis
    TBN - 0.1
    Visc - 615.3
    FP - 435
    Calcium - 3
    Magnesium - 1
    Phosphorus - 4
    Zinc - 2
    Lake City, Fl.
    Onyx Black
    2001 Camaro Z28
    I got the seafoam out of there today and ran some cheap oil through for about an hour, then changed again. I hope I didn't screw anything up, I was following some of the suggestions on the can and other members
    Good man. I know members here scream about SeaFoam. Many voted for Obama also.
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Member TexasLS1's Avatar
    Cedar Park, Texas
    '72 Chevy C10 SWB
    First time I've read this, so I've gotta subscribe. Thanks for the info, Sarge!
  1. Seafoam?
    By Ramairgod84 in forum General Help
    Last Post: 04-13-2010, 01:27 PM
  2. Question: SeaFoam
    By WhatUpWhatUp in forum Showcar and Detailing
    Last Post: 03-10-2010, 07:56 PM
  3. seafoam again
    By gsxrsteve in forum General Help
    Last Post: 08-15-2008, 10:15 AM
  4. Seafoam
    By chuckie669 in forum Internal Engine
    Last Post: 08-07-2008, 04:18 AM
  5. anybody ever use seafoam ??
    By Speedy_Gonzales in forum Internal Engine
    Last Post: 05-28-2007, 04:52 PM
