Thread: how to adjust the iac valve
05-23-2009, 02:20 PM #1Junior Member
- May 2009
- albany ga
i just bought a new larger throttle body and i bought new iac and tps sensor well the iac how to do set it you can srew the plunger in and out to set the depth i do not have a old one to look at so i do not know were to set it atdo i need to make it were it closes the hole off completely while i am looking at it or is there a measurement thanks
05-24-2009, 03:04 AM #2
I didn't know there was an adjustable one. It should screw it self in & out automatically ???
05-24-2009, 03:26 AM #3
Don't mess with the IAC, it is set by tables in the tune, idle air, throttle set screw, etc., it is not adjustable manually.
05-26-2009, 09:56 AM #4Member
- Sep 2005
- south, GA
Silver- 00 Formula Firehawk
It is definitely not adjustable unless you program the pcm.
New valve stem seals the same for exhaust and intake valve?
By JehalinTA in forum Internal EngineReplies: 1Last Post: 07-03-2011, 08:16 AM -
JEGS stud mount valve spr. compresor vs. Speeds valve spring
By JehalinTA in forum Internal EngineReplies: 0Last Post: 05-30-2011, 05:16 AM -
D-Port Head Valve Upgrade - Big-Valve Performance on a Small
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 04-20-2011, 04:10 PM -
Valve cover gaskets, Valve Springs, Timing Gasket
By Dewman in forum Parts For Sale / TradeReplies: 0Last Post: 01-22-2010, 08:14 PM -
The proper way to adjust a throttle valve cable for '93 4L60?
By N20LT4 in forum Automatic TransmissionReplies: 0Last Post: 12-11-2007, 11:20 AM
