    May 2008
    New Brunswick
    New Cat touches Fuel Line !!
    Has anyone here ever installed a set of pacesetter headers with thier matching TSP catted Y-pipe on an F-body.
    It doesn't seem to fit at all. It hangs LOWWWWW, and its about 2.5" too long to bolt up to my corsa cat back system.
    But the big issue is that the cat on the drivers side is sitting so that it runs across the fuel and brake lines, with maybe a quarter inch of clearence. This doesn't sound good to me.
    I asked my exhaust guy if he had the y-pipe on upside down and he swears that he tried it the other way and it didn't fit at all.
    Currently the way it sits, the drivers side cat is the one that is farther back towards the rear and the one having the issue...the passenger side cat sits nicely under what appears to be a large heat shield and has TONS of clearance.
    Any advice welcome...
    Urbandale, IA
    2002 Trans Am WS6 (M6)
    Can't answer about your setup but with my Kook's I swapped the plastic clips holding the fuel/brake lines in the transmission tunnel. Unbolt them, turn them upside down, put your lines back in the plastic clips (make the new top a little larger for the larger fuel line), and reinstall. I did it by myself but with someone helping it will be much easier to hold the clips and thread the bolt at the same time. This will gain close to a couple of inches of clearance.
    May 2008
    New Brunswick
    I thought about doing that...but they are going to be damn close to jamming against that (can't remember name) 4' long triangulated bar that mounts off the transmission right in that location.
    Omaha, NE
    2000 Z28 Camaro
    That long bar is the torque arm.
    Urbandale, IA
    Quote Originally Posted by allbaugh_04 View Post
    And the relocated lines will miss the torque arm.
    Junior Member metalmechanic's Avatar
    new iberia la.
    2002 Firehawk T/A
    with my kooks hdrs $ y, it was close, i had to bend the heat shield up a little, drvs side
  1. ls1 fuel rail 98-? single fuel line
    By LEADSLED in forum Parts Wanted / Trade
    Last Post: 12-08-2011, 02:50 PM
  2. For Sale: LS1 Fuel Rail Covers with 2 Fuel Line Cutouts - Cut for F-Bo
    By '99 SLP#24 in forum Parts For Sale / Trade
    Last Post: 01-11-2011, 07:24 PM
  3. kinked fuel line while changing fuel filter
    By krese in forum Firebird / WS6
    Last Post: 10-04-2010, 04:02 PM
  4. need a fuel line
    By robznob11 in forum Parts Wanted / Trade
    Last Post: 05-16-2010, 07:29 AM
  5. Removing fuel supply line from fuel rail
    By GatorSS in forum General Help
    Last Post: 01-02-2007, 06:10 PM
