Results 1 to 19 of 19
Thread: pros and cons: 99 Z28 vs 96 SS?
05-19-2009, 08:33 AM #1Member
- Jun 2006
- somewhere over the pond
black / black- '91 Z28 / '10 SS
Actually I own the nbm 99 Z28, 6 speed, hardtop.
Just seen a '96 SS in green met., auto, t-tops for sale near me. that makes me think about trading the Z for the SS.
Both cars are in a good condition.
Since it is a daily driver I wouldnt mind the automatic.
What are the pros and cons about this trade?
05-19-2009, 08:50 AM #2Junior Member
- Apr 2009
- washington
your Z28 is a ls1 the 96 is an lt1.
your z28 is way easier to upgrade and upgrades have bigger benefits than the ss would have.
your z28 has a decent value and always will because of the engine in it. If you look online you can find 97 and under camaros for like 3000 because of the fact there isnt really pros about having it over the z28.
05-19-2009, 09:23 AM #3
opti-spark is definatley the way to go
What makes you consider the trade, the looks, t-tops, what?
05-19-2009, 10:08 AM #4
05-19-2009, 10:13 AM #5Member
- Jun 2006
Well the front end is what I think is really much nicer than the LS1.
Regarding the upgrades, we are really limited to some basics over here because we have some very restrictive, stupid laws. On the other hand the output for a daily is enough in both cars.
Is the optispark problem that bad?
05-19-2009, 10:38 AM #6Consumer of kraut
- Dec 2006
- Jenks/Tulsa
Light Pewter Metallic- y2k 8-cylinder catfish
LS1>LT1, I know, I owned a '94 Z28 and there's no comparison. And, as others have said, Optispark. You lose that, get ready to spend some green. I nearly bought a '97 SS before I got my first LS1, which happened to be a '99 Z28. I'm very glad I decided against the SS.
05-19-2009, 10:38 AM #7
The opti spark SUCKS! Ive had 2 Lt1's and both the opti's went out and they were such a pain in the ass That I sold them and got my LS1 but there both camaros/fbodys and there both nice cars but I think id go LS1...
05-19-2009, 10:50 AM #8Exalted Cyclops
- Feb 2007
- San Diego, CA
DAMN you opti!
05-19-2009, 11:49 AM #9Awaiting Activation
- Feb 2007
- onaway,MI
black- 2000 Z28
I've heard a lot of problems around here with the lt1s too. Stick with what you've got. You'll be happier in the long run.
05-19-2009, 06:07 PM #10
Yes its that bad and then some. Let me give you an example, when I first got my LT1 I wanted to do a complete tune up. Pressed for time I called around and the cheapest price I got to do a full tune up on an LT1 was about $825 bucks. About 70% of that was labor. There were a couple of shops that refused to work on them. You have to take damn near the whole front of the motor off. And most will tell you if your going that far you might as well replace the water pump and the distributor itself. If the water pump ever leaks, it will destroy the opti. The distributor has a rubber seal that keeps the oil out of the opti. If it ever leaks it will destroy the opti. So you end up replacing parts that have nothing to do with the tune up. You don't have to replace these parts but you would be stupid not too. Pretty expensive even if you do the work yourself. And by the way that $825 bucks I talked about earlier did not include replacing the water pump or distributor housing. Trust me stick with the LS1.
05-19-2009, 07:39 PM #11Royal pain in the....
- Aug 2007
- savannah, ga
2001 Z-28 A4 NBM- 2002 35th anni SS M6#1696
keep your LS engine/6 speed
you can get more power/more miles/and better MPG with what you have.
you would not be happy in the the long run. I got out of an lt/auto into an LS/m6...i aint goin back.........
05-19-2009, 07:48 PM #12You've Seen The Butcher
- May 2009
- Indiana
2009 Silverado Z71- 2003 Corvette MN6 Black
My buddy used to have a 93 Z28 LT1, he went to change the Thermostat and leaked coolant down the front of the engine.. after that the car would not start, couldn't figure out why until a Mechanic said, "You need a new Distributor." ($900) Now we both have LS1 Camaros and love them way better. I like the Front End and interior better on the LS1 as well.
05-19-2009, 08:37 PM #13
05-19-2009, 08:43 PM #14
I wouldn't trade an LS1 F-body for an LT1 F-body. You're downgrading in every department. The biggest two differences are the engine and the brakes.
Just look at the LT1 engine next to the LS1. The LT1 is a disaster of hoses and wiring with absolutely no room to work on it. Everything is a bitch on the LT1. Its basically a Chevy Small block with Opti Spark and tons of emissions crap. Changing the spark plugs is difficult on an LS1 car, on an LT1 its damn near impossible thanks to almost zero clearance between the valve covers and strut towers, as well as the cast iron manifolds that block everything.
LS1 is newer, yet a much simpler and easier to work on design. Everything is better - no distributor, more clearance in the engine bay, better components and gaskets, and the air pump was relocated to the fender and out of the way.
The brakes are also much different. The LT1 cars use old style, cast iron single piston calipers up front with 10.8" rotors. The spindle is the caliper bracket as well. LS1 cars use dual piston PBR aluminum calipers with 11.8" rotors, and the caliper brackets bolts to the spindle separately. The braking capabilties are significantly better with the LS1 brakes, there is really no comparison.
05-19-2009, 10:17 PM #15Member
- Jun 2006
ok ok, I'm gonna keep the LS1.
Specially for a daily driver brakes and also gasmileage are a concern.
Thanks for the help!
05-21-2009, 07:28 PM #16
05-22-2009, 12:24 AM #17Member
- Jun 2006
05-22-2009, 07:46 PM #18
The LS1 has many upgrades over the old style small block. The heads are superior in breathing capabilities. Gets rid of the center "hot spot" on the heads also. Aluminum construction saves weight and disburses heat better. The angle of the heads have also changed, adding to the flow potietial. The lower end of them (as in the block and main cap design) is pretty bullit proof, with minor mods. I build hot rod engines, and I am done with the old style. On with the LSXXX. John
05-25-2009, 12:09 AM #19Senior Member
- May 2009
- Toronto
SOM- 2002 SS
I just bought an 01 hardtop 6 speed. My brother bought a brand new 97 ss. There are pros and cons but way more pros for the ls1. Personally I prefer the pointy nose of the 93-97 and the looks of the 96/97 ss the best. The opti isn't as bad as everyone says. I've had my vette for 11 years now (93) and the opti died on me once. For anyone with any brains the labor to do this job is very very simple. I can swap an opti now in less than an 1/2 hour. Mind you I did this on my vette which has more room to work on. The ls has much more pros going for it. Lighter motor. More power (about 20-30 rwhp more) and a way bigger aftermarket. the ls motor itself is an incredible motor. there is nothing 'bad' about the lt1 the ls1 is just a way way better designed motor from the bottom up.
AZ: Pros and Cons??
By mrz28m6 in forum Almost Anything GoesReplies: 10Last Post: 04-09-2012, 03:34 PM -
Cut out pros and cons
By wanna_lS1 in forum Firebird / WS6Replies: 9Last Post: 01-27-2010, 06:56 PM -
Question: Pros and Cons No Maf
By lancesT/A in forum Computer & TuningReplies: 7Last Post: 09-25-2009, 06:40 AM -
Pros and cons?
By NJ2002WS.6 in forum General HelpReplies: 28Last Post: 04-09-2008, 09:33 AM -
pros-n-cons
By blacksheep in forum Camaro / SSReplies: 10Last Post: 09-30-2006, 04:18 AM
