Thread: Rear or Gears?
05-18-2009, 10:53 PM #1
Rear or Gears?
I have a 98 formula with about 120,000 miles on the stock rearend. My codes read GU2 which I believe are 2.73's... So I know that I'm being robbed at the low-end...
So my question is would you guys encourage putting in some better gears, or just wait till the stock one is shot and replace it with a stronger rear-end all together?
Has anyone done a gear swap with as many miles as me?...
Thanks for looking.....
05-18-2009, 10:55 PM #2
Check around here, everywhere. Save your money and put it towards a 9"... maybe a 12 bolt
Dont dump money into that 10 bolt.
05-18-2009, 10:57 PM #3Just me
- Nov 2006
- Broken Arrow, OK
I would wait and just upgrade the entire rear. My thought process, eventually the 10 bolt is gonna blow, so why throw any money away on it. If you spend $200 on new gears and then $$$$ for install, thats money down the toilet if/when the 10 bolt blows. That same money could have put you closer towards an upgraded rearend.
05-18-2009, 10:59 PM #4
good points and thanks for the advice guys...
05-19-2009, 08:31 AM #52 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
Yes absolutely, Rule of thumb is to upgrade and not rebuild with the POS 10 bolt
05-19-2009, 07:08 PM #6Senior Member
- Apr 2008
- Madison, WI
A stronger rearend is always the better option, but I might not pass over a cheap used 10 bolt rearend with 3.42s or something if you want a quick cheap (possiblly temporary) upgrade. Honestly a 10 bolt is fine for a mostly stock automatic LS1.
05-19-2009, 09:25 PM #7
If your an auto then you can maybe get by with a used 10 bolt as some said, but it may only be temporary.
I invested in a moser 9 inch, couldn't be happier with it.
05-19-2009, 09:31 PM #8
9" all the way, don't bother with anything else.
Rear Gears Help!?
By prater_1 in forum DrivetrainReplies: 5Last Post: 04-18-2012, 09:48 AM -
WTB LT1 rear end with 3.42 gears (So Cal)
By nhra-trans-am in forum Western MembersReplies: 9Last Post: 10-17-2007, 11:47 AM -
Rear Gears
By ls1speedster in forum DrivetrainReplies: 6Last Post: 08-01-2007, 08:09 PM -
Rear Gears.
By ls1speedster in forum Computer & TuningReplies: 3Last Post: 07-16-2007, 08:14 PM -
Rear end gears?
By Jeff Jones in forum DrivetrainReplies: 30Last Post: 06-01-2006, 02:50 PM
