Results 1 to 20 of 20
    Member blackcar's Avatar
    Arkansas
    '02 Z28 parting-out
    Had to rescue wife
    My wife called and said she was on the side of the rode. She drives a 2007 Ford Fusion automatic (I know that’s 90% of the problem). She had been going along with the cruise on and the drivetrain light came on. She said when that happened the car “wouldn’t go”. So she pulled over and killed it. When I got there, I looked over the car and underneath and checked fluid levels. Everything seemed fine. I let her take my truck to work and I took the car for a test spin. I drove for about 20 mins no prob. Thought everything was ok. On the way home I decided to play a little (never got to play much in her car). After finding out the governor was at about 113 a couple of times I thought it was time to head home. On the way home the check engine and drivetrain light come on. I give it gas and it is like the brakes are on. It would hold speed but not pick up at all. So I pull over, kill it, set there for a min, and start it up. Everything is ok now but the check engine light is still on, which I can understand. But does anyone have an idea of what is going on with the drivetrain?
    Arkansas
    '02 Z28 parting-out
    bump
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Maybe a vehicle speed sensor fault?
    Member jambofla's Avatar
    Northwest Florida
    2002 SS
    no codes?
    ever changed the fuel filter?
    start with the cheap fixes first
    carb cleaner, air filter, fuel filter, oil change
    then it's logger time because you know it will never do it while you have it plugged into diagnostics.
    Member zmg00camaross's Avatar
    missouri
    pewter
    2000 camaro ss
    i guess there no warraty left on the car
    Arkansas
    '02 Z28 parting-out
    Quote Originally Posted by jambofla View Post
    no codes?
    Never changed anything but oil and air filter. Changed the oil last weekend and put a K&N air filter in about 6 months ago. It has 46,000 miles on it. I think I'm just gonna let the wife drive my truck to work tonight and let her car sit. Then Monday take it and put the scan tool on it to see what it says. I was hoping to move some stuff this afternoon and it won't fit in the back of the Camaro. I could let her drive the Camaro and I keep the truck. But she knows that isn't happening.
    Arkansas
    '02 Z28 parting-out
    Quote Originally Posted by zmg00camaross View Post
    Too many miles.
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    Noithing seems wrong to me
    In all seriousness I have no idea good luck
    Glen Carbon, IL
    At least the problem is circled. Found On Road Dead
    Arkansas
    '02 Z28 parting-out
    Quote Originally Posted by 02blkws6 View Post
    Yeah, that's what I told her. But she bought it before we got hitched.
    missouri
    pewter
    2000 camaro ss
    I would drive until the check engine light stays on or drive it while it's acting up then check codes
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    first thing a dealer is gonna say..."the oil from the k&n damaged the mass air meter,replaced it and your are all set."until it happens again then they will throw a different part at it.k&n filter should be taken out before you go to a dealer or repair shop because 9 times of of ten the "tech"will say contaminated mass air meter and will not try to find the real problem.just a suggestion from a ex-ford tech,and sorry i left the business in 05 and have never turned a wrench on a fusion.
    Arkansas
    '02 Z28 parting-out
    Quote Originally Posted by 02transamce View Post
    Thanks for the advice. I was going to take it to a small shop I use sometimes. I rarely take anything to the dealer. Any ideas on what would make a "powertrain" light come on. I can understand the "check engine" emmisions light coming on after running WOT for a while. But I don't have a clue as to what would make the "powertrain" light come on. What sensors feed that light?
    Arkansas
    '02 Z28 parting-out
    Well the code says there is a prob with the "throttle activated control". It's drvie by wire. Talked to our local Ford dealership and they are going to fax me the part of the service manual that covers it.
    Bay Area
    my highbeams
    Throw some water in the gas tank drive it around and problem solved.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    throttle blade sensor or accelerator pedal sensor probably freaked out,i'm not a big drive by wire fan,too many things could and do go wrong.good that the ford store is willing to help you,usually the will just say"bring it in."
    Arkansas
    '02 Z28 parting-out
    Yeah, I'm not either. Is there a way to tell which one it is? With out changing one and see if it happens again.
    Arkansas
    '02 Z28 parting-out
    btw: Code is P2100
    Arkansas
    '02 Z28 parting-out
    Found a service bulletin:
    Component Description:
    2. POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM) Bulletin Number: 072315
    Bulletin Date: Nov 2007
    Vehicle: 2,007 Ford Fusion
    Summary:
    MIL ON--DTC P2100 AND P2110 IN MEMORY - 3.0L ENGINE. ( NHTSA ITEM NUMBER - 10023866 )
    Called the dealer to see what we need to do and he said it needs to be re-calibrated. 1 hour labor $69.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    cool,that is not a bad price,the dealer i worked at charged $80 an hour labor rate 4 years ago.hope that solves your problem.
  1. HOT ROD To The Rescue
    By Ed Blown Vert in forum General Help
    Last Post: 10-18-2012, 11:20 AM
  2. HOT ROD To The Rescue
    Last Post: 08-10-2012, 12:50 PM
  3. Rescue Me
    Last Post: 06-14-2007, 08:03 PM
  4. Rescue Me!!
    Last Post: 05-24-2006, 07:00 PM
  5. Rescue Me
    Last Post: 05-05-2006, 08:35 PM
