Results 1 to 3 of 3
Thread: Thermostat blues
05-16-2009, 02:55 PM #1
Thermostat blues
Just wondering if my assumption is correct.
My car was tuned with a stock thermostat.
So I take it upon myself to install a 160 thermo for the summer . and drive it for a week or so and seem to notice terrible gas mileage, loss of power , and a seemingly over rich condition at an idle .
I am sure that it is because the engine is not reaching normal operating temp.
So I remove the thermostat and install a new 187 deg thermostat, and bingo it fixed it.
I think the engine would have been more forgiving of the colder thermostat if I hadn't been running a colder NGK TR6 spark plug for the nitrous .
Does anyone agree or am I just crazy.
05-16-2009, 05:05 PM #2
I'll let someone else tackle the "running bad" issue. The only thing I will note is that when installing a cooler thermostat you also want to reprogram your fan settings to come on sooner. Even with a 160 stat you should be ok as the engine will actually run warmer than that. With my 180 thermostat, and reprogrammed fans, I see a range of 185 to 192 degrees depending upon engine load.
05-18-2009, 07:40 AM #3MOTOR CITY MARO'
- Nov 2005
- LIVONIA,MICHIGAN
PEWTER- 2000 CAMARO SS #3821
I think your 160 would have ran around 180 because nobody on here has ever had a 160 actually run down that low. maybe you had a bad stat?
Moser-9 I got the blues
By midnitejam in forum DrivetrainReplies: 23Last Post: 06-19-2011, 09:29 AM -
What's your 'Blues' name? (Fun Game!!)
By Elimin8tor Z28 in forum Almost Anything GoesReplies: 38Last Post: 08-12-2008, 09:00 PM -
I got the emmission blues...
By swifty in forum Rocky Mountain MembersReplies: 11Last Post: 05-09-2006, 09:34 PM -
insurance blues......
By predator in forum Almost Anything GoesReplies: 23Last Post: 02-22-2006, 08:16 PM
