Thread: Turn signal swivel?
05-16-2009, 12:40 PM #1I'm (Hurst) Equipped...
- Oct 2006
- Santa Barbara County,Ca.
Onyx Black- '02 Camaro SS(replica) M6
Turn signal swivel?
Hey everyone, tried doing a search on this w/ no luck. Has anyone seen this before? Any ways, my turn signal stalk was gettin a little difficult to engage one day. Then finally somethin inside the column snapped, 'cause the stalk just went limp. I figured it was the turn signal switch assem. (cam) that broke, no sweat right? So I go in to swap it out, and I find this small metal swivel that joins the (bolted to the) signal cam to the turn signal stalk (swivel). Here is a diagram and a pic.
Has anyone else have this happen?!?
Oh yeah, the car is a 2002 Camaro...
05-16-2009, 02:12 PM #2Impounded
- Oct 2007
- Beaver Dam KY
Should be a pretty easy part to find.
Please select a corresponding number from the illustration below to view the details of that part.
1) Clockspring 2) Cancel cam 3) Signal switch
4) Actuator 5) Wire shield 6) Lock cylinder Manual trans
7) Key alarm switch 8) Wiper switch 9) Pivot pin Signal lever
10) Dimmer actuator 11) Column cover 12) Cover plate
13) Cap 14) Housing assy 15) Lock pin
16) Tilt lock W/o notch 17) Shaft Ignition switch 18) Release lever
19) Rack package 20) Ignition rack Spring 21) Tilt spring kit
Its part number 4 I do believe from gm parts direct
05-16-2009, 04:26 PM #3I'm (Hurst) Equipped...
- Oct 2006
Awesome! someone knows what I'm talkin about! Yeah it's #4 in the diagram.
That POS was probably a cheap overseas part... U know the name of the part?
Oh, duh! ACTUATOR! Thanks.
05-16-2009, 04:58 PM #4I'm (Hurst) Equipped...
- Oct 2006
Well... order placed thru GM Parts direct! Only have to wait a week now! LOL!
Thanks again JoshieD.
05-16-2009, 06:49 PM #5Impounded
- Oct 2007
- Beaver Dam KY
03-16-2010, 04:21 AM #6
Anyone know if you can locate this part at a GM dealer? My T/A is ripped apart and i just found out that it is the 4.) actuator...the site doesnt list a GM part number. Any help would be appreciated.
03-16-2010, 08:13 PM #7I'm (Hurst) Equipped...
- Oct 2006
Hmmm... Lucky I'm still subscribed to this thread Lol. When I recieved the part from GM Parts direct I didn't even use it ( I ordered 2 of them). I (carefully) TIG
welded the old one back together. Anyways the part number is GM# 7827038 "ACTUATOR". Hope u can still get it from a dealer... If not PM me and I can sell u one of mine.
Turn Signal
By wkstyle in forum Firebird / WS6Replies: 5Last Post: 09-30-2015, 07:19 AM -
Turn signal?
By GrapeApeTA in forum General HelpReplies: 15Last Post: 01-23-2011, 12:14 PM -
right turn signal
By bgon99ss in forum Stereo and ElectronicsReplies: 18Last Post: 04-19-2010, 09:49 AM -
Help: help with turn signal
By danmeksch in forum Camaro / SSReplies: 9Last Post: 01-19-2010, 03:25 PM -
Turn signal help
By Blksilvr in forum General HelpReplies: 7Last Post: 08-08-2007, 05:46 AM
