    Member cowstandmoto's Avatar
    Houston, Texas
    Dark Blue Metallic
    2002 Trans Am WS6 M6
    shocks and springs
    has anybody had trouble taking the front shock/spring assembly apart?
    explain trouble? loosening the nut by hand is pretty hard to do. I took mine (with the spring compressors installed) to a shop so they could bust them apart with air tools.
    Houston, Texas
    Dark Blue Metallic
    well, i put the spring compressors on the spring and started cranking on the compressor bolts. i kept cranking and cranking and cranking, but it just wouldn't bust apart. i cranked it so far that the compressor bolts started bending. could rust be the problem? the previous owner didn't take care of the car. you wouldn't believe how bad this thing is rusted underneath. it's obvious that they drove it on snow and salt roads all the time.
    Houston, Texas
    Dark Blue Metallic
    the upper shock mount, shock bumper and shock cup are all stuck together on the top of the shock. do you think maybe squirting some machine oil and whoopin it with a hammer might do it? i have bought some lowering springs that i want to put on.
    Omaha, NE
    2000 Z28 Camaro
    I've personally never done the front springs yet, but isn't there some spray out there that you can use to help loosen bolts?
    Houston, Texas
    Dark Blue Metallic
    there is Liquid Wrench but i already tried that. i know that machine oil is good for a lot of things. i used to have a can of it back in the day. i think i'm going to see if i can find some and try it out. thanks guys for the input. preciate it!!
    wow, never heard of something rusted to rubber that badly!
    Houston, Texas
    Dark Blue Metallic
    well, you should see the underside of this car. redicules. i'm probably going to end up spraying it with WD40 and beating the crap out of it with a rubber mallet.
    That is nothing. Helped a friend install his BMR springs, and we ended up having a shop torch the strut boot to get it loose.
    Ended up having to replace the entire shock and tower boot. Luckily I found someone local with a used shock we could use.
    Junior Member kccutthroat's Avatar
    kansas city
    blacc
    99 Firehawk
    compress the spring from the control arm with a jack the put the compressor on as tight as possible keep the top bolted in and take out the bottom nut then drop the jack slowly and that son of a bitch is out!! we dropped mine in an hour! the hardest part was disconnecting the bracket holding the control arm in (sorry dont know what its called off hand). smack that bitch with the hammer after taking the nut off
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    I took mine out and had a shop with a wall mounted spring compressor seperate the assembly. It still took us 3 hrs at the shop to get both sets apart PITA.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    kansas city
    blacc
    99 Firehawk
    i bought my strut/spring preassembled
  1. Question: shocks/springs
    By 98maro in forum Suspension and Handling
    Last Post: 02-24-2011, 01:36 AM
  2. Question: shocks n springs
    By 98Bruiser in forum Suspension and Handling
    Last Post: 08-29-2010, 06:07 PM
  3. Help: shocks n springs
    By reaper ws6 in forum Firebird / WS6
    Last Post: 08-11-2010, 02:40 PM
  4. Shocks and Springs
    By ss2000 in forum Suspension and Handling
    Last Post: 05-15-2009, 03:46 PM
  5. Stock Springs, Shocks, & Springs
    By Bloodta in forum Parts For Sale / Trade
    Last Post: 05-20-2006, 02:35 PM
