Results 1 to 14 of 14
    Junior Member David Ray's Avatar
    Lake City, Fl.
    Onyx Black
    2001 Camaro Z28
    Missing Header Bolt = Engine Noise?
    I been hearing a tapping noise in my Z28's engine. It goesn't go away at warm-up and increases with acceleration. Today, I tried to isolate the sound and tracked it to the driver's side of the engine. I discovered that the front header bolt was missing on that side. Could this cause the tapping? Can I replace the bolt or does the gasket have to be changed as well?
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Quote Originally Posted by David Ray View Post
    Gasket is most likely fried from the heat. It wont take long at all to get a set of MLS(metal) gaskets from autozone and a set of locking header bolts installed.
    Lake City, Fl.
    Onyx Black
    2001 Camaro Z28
    What do the bolts have to be torqued to? What are locking header bolts? They have them at A.Z.?
    Beaver Dam KY
    79 T/A -91 Firebird
    Yup. item number sta_8900. They prevent the bolt from backing out.
    18 foot lbs
    Lake City, Fl.
    Onyx Black
    2001 Camaro Z28
    What about that copper gasket sealant? Is it any good? Should I change both sides or do I have to 'cause I ain't tried it before and I don't want to screw anything up.
    Beaver Dam KY
    79 T/A -91 Firebird
    The kit will be for both sides. Do it once and right. No sealant is needed
    I'd avoid the sealant, as long as your headers have fairly thick flanges you should be fine. Although there is no need to do anything to the other side, it wouldn't be a bad idea to at least install the locking bolts, which means you may as well swap out the gasket too.
    Lake City, Fl.
    Onyx Black
    2001 Camaro Z28
    10-4. Thanks alot.
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    You might want to prepare yourself for the worst. Very few instances of bolts backing out, more often than not, they are missing because they were cross threaded or stripped. Take your time and as said above - do it once and do it right.
    try to put a bolt back in there first. I bet that'll fix your problem.
    Lake City, Fl.
    Onyx Black
    2001 Camaro Z28
    Do I need to use anything on the threads since the heads are aluminum?
    Lake City, Fl.
    Onyx Black
    2001 Camaro Z28
    I forgot to add that the gaskets now in place are metal. Will that make any difference?
    I didn't use anything on my header bolts but if they're stainless bolts you can put a little antiseize on there if you want too. Check and make sure it's not stripped or something like that and put a bolt in there. Imagine that should take care of it. The stock gaskets are metal and extremely durable.
    Lake City, Fl.
    Onyx Black
    2001 Camaro Z28
    Thanks.
  1. 98 z28 after header install cec light and missing
    By johnshuler08 in forum External Engine
    Last Post: 09-07-2008, 03:34 PM
  2. Missing VIN on Engine Block
    By Mickey Bankhead in forum External Engine
    Last Post: 03-16-2007, 09:53 AM
  3. header noise
    By fkreager in forum External Engine
    Last Post: 06-16-2006, 06:41 AM
  4. Engine missing really bad.... sometimes?
    By danman in forum External Engine
    Last Post: 05-22-2006, 04:17 PM
  5. Engine missing really bad....sometimes?
    By danman in forum General Help
    Last Post: 05-21-2006, 11:10 AM
