Results 1 to 14 of 14
05-08-2009, 08:51 AM #1Junior Member
- Mar 2009
- Oakdale MN
Silver- 1998 z28 convertible
Extremely hard to get out of park
I have a automatic tranny in my z28 and whenever it sits for a while, like overnight, it is extremely hard to get out of park. The button is getting stuck on something and i can't push it down but once i get it out of park it is fine until the next morning. I have pulled apart the counsel and greased that all up. I have also messed with the cable by the tranny but still no luck. anybody else have this problem or know how to fix it?
05-08-2009, 03:31 PM #2Member
- Nov 2008
- harrisburg pa.
black- 02 vette vert
i had the exact same problem. once you got it out of park once it works fine every time after, right? i did what you did, lube everything, pulled the knob to check its operation, nothing worked. bought an aftermarket shifter knob, t-handle style with the button on the end,[firebird style]. works perfectly every time! could be that the camaro style is pushing straight down on the release shaft, and the firebird style is sliding across the shaft performing a wedge type action to push it down.[?] actually thats what it is doing, i meant that may be why it works better. check ebay for finger grip t- handle shifter or something close to that.
05-08-2009, 07:37 PM #3Just me
- Nov 2006
- Broken Arrow, OK
Sounds like your parking pawls. Its recommended to put the ebrake on prior to putting the tranny in park. This will keep stress off the tranny and should resolve your problem about being difficult to get out of park. Remember to apply the ebrake prior to putting it in park though
05-08-2009, 08:14 PM #4Member
- Nov 2008
- harrisburg pa.
no, not in my case. i parked in the garage [level floor] and it would work smooth as silk, came out the next morning and it was stuck[or at least very stiff maybe] again. after getting it to move the first time it worked smooth as silk all day. now it works great all the time. dont know exactly why except the other style handle was the cure. just to clarify my situation, it wasnt getting it out of park,but actually getting the button to push in to operate the pushrod to get it out of park that was the problem. didnt appear to be anything wrong with the plunger or anything else. binding pawls wouldve shown up after pushing the button in and trying to pull the shifter back. its kinda wierd, and maybe a little long winded too for a seemingly simple problem.
05-09-2009, 06:43 PM #5Junior Member
- Mar 2009
- Oakdale MN
well i will try the e brake thing tonight and see if it is any better in the morning. i will let you know if it works. thanks for the tip
05-10-2009, 04:06 AM #6Member
- Nov 2008
- harrisburg pa.
if youre parking on a hill, put the e brake on before putting in park and if that works youre good to go, dont forget to pull it out of park before you release the brake or you defeat the purpose. if its the button is pushing hard still i think youre back to my solution.
05-10-2009, 06:11 PM #7Junior Member
- Mar 2009
- Oakdale MN
05-10-2009, 06:47 PM #8Member
- Nov 2008
- harrisburg pa.
05-25-2009, 10:24 AM #9Member
- Nov 2008
- harrisburg pa.
05-25-2009, 11:37 AM #10Senior Member
- Apr 2008
- Madison, WI
Sounds like a problem with the BTSI (pronouced Bitsy) with stands for Brake Transmission Shift Interlock. When you press the brake pedal, the BTSI solenoid lets the button be drepressed. Try replacing the BTSI solenoid or just mechanically unhook it from the shifter if you don't want that safety feature.
05-25-2009, 03:26 PM #11Member
- Nov 2008
- harrisburg pa.
i still have to go back to my experience, exact same problem,going from a push straight down button to an end button which slides across and wedges the shaft down solved the problem. original knob works perfectly free and smooth off the car also. i know youre thinking there must be something else, but trust me this solved the problem. its not like i can push harder on this style either, it just works perfectly smooth every time.
05-26-2009, 03:30 PM #12Senior Member
- Apr 2008
- Madison, WI
ahhh I see. The first time I read your post I thought you put an aftermarket shifter in it, which would most likely not use a BTSI. But I see you actually said "aftermarket shifter knob."
05-26-2009, 03:57 PM #13Junior Member
- Mar 2009
- Oakdale MN
05-26-2009, 04:38 PM #14Member
- Nov 2008
- harrisburg pa.
Extremely pissed off Can you help?
By illcul8troffcr in forum General HelpReplies: 36Last Post: 10-29-2008, 07:07 PM -
Gear shift button extremely hard to push when in park
By Zimbabwe_3 in forum General HelpReplies: 9Last Post: 06-26-2008, 06:01 PM -
Question: Extremely Hard water spots??
By illcul8troffcr in forum Showcar and DetailingReplies: 8Last Post: 04-26-2008, 08:15 PM -
Virginia Motorsports Park Drag Racing and Car Show - PY Pontiacs In The Park
By Ed Blown Vert in forum GTOReplies: 0Last Post: 11-30-2007, 06:00 PM
