Thread: question about shift kits
05-07-2009, 08:23 PM #1Junior Member
- Mar 2009
- fairton, nj
if i buy a transgo shift kit for my 02 z28 will it really make a big difference in the life of the transmission? i plan on running a 3,000 or bigger stall speed converter and a trans cooler, if anyone can help me it would be great thanks
05-08-2009, 09:34 PM #2
usually makes the clutches last longer ,and gives you a seat of the pants upgrade!
05-08-2009, 09:47 PM #3
i put my b & m shift kit in, and i'm not too sure if it had anything to do with it, but about 2 thousand miles after my transmission went out; after that I had my transmission rebuilt with stronger internals and (what they call) a stage 2 transmission (it really pounds into 2nd gear) I haven't had a single problem with the tranny after having it built, but I'm in the process of replacing my 2nd rear end. POS 10 bolt
but yes, theoretically it should help your transmission.. I think mine was just at the end of its time, and the shift kit just made it take more of a beating.
05-09-2009, 07:33 AM #4
I was thinking about going with a shift kit but instead i did a mail order tune from frost with a tranny cooler. He changed the shift points of the tranny and now it snaps into gear in WOT.
05-10-2009, 04:32 PM #5Member
- Nov 2008
- harrisburg pa.
black- 02 vette vert
lead me around the old and new tech. if you can still install a shift kit for improving shift characteristics, why do a tune on transmission? or if through a tune you can change shift points and increase pump pressures etc for improved shifting, why do a shift kit? are there significant differences in what each of these can accomplish? one better? one cheaper? just looking for which way to go when i get there. also does the mileage on the trans make 1 better than the other? any
body with some good input, feel free.
05-12-2009, 04:26 PM #6Member
- Nov 2008
- harrisburg pa.
no info on this?
05-13-2009, 02:56 PM #7
in my personal opinion if you have he ability to go through the ecm and change the shift char. for the same price as a shift kit ,that would be the way to go , mostly because the shift kit has you drill larger holes through the seperator plate in the valve body, which if you drill a hole ,you cant easily reverse it but if you just change a variable in the ecm and you dont like the feel of the shift you can chage it again, no holes to shrink,lol, .and if you havent had the torq. management taken off,or a tune done just have it done then! but the best option is to flip the accumulator and spring arrangement and turn the epc sol. up 1/4 turn. itll out do any shift kit for free!
05-13-2009, 07:29 PM #8Member
- Nov 2008
- harrisburg pa.
05-18-2009, 07:27 AM #9
It is a long running debate as to weather a shift kit actually prolongs the life of an auto trans. Debate is still running but the basic opinion is yes and no. lol. One thing everyone will agree on is HEAT KILLS. Keep it cool by getting a larger capacity pan, good trans cooler, and good fluid. Keeping the fluid fresh and cool will make it last longer for sure.
Question: shift kits?
By crazy dave ls1 in forum Automatic TransmissionReplies: 1Last Post: 02-09-2009, 03:20 PM -
Shift kits for A4
By Bigdaddy in forum Automatic TransmissionReplies: 10Last Post: 10-25-2008, 08:57 AM -
Shift kits for a a4 WS6
By Itllrun in forum Automatic TransmissionReplies: 5Last Post: 08-31-2008, 11:46 PM -
What is the diffrence between in Shift Kits
By mglangley21 in forum Automatic TransmissionReplies: 1Last Post: 08-14-2007, 07:25 PM -
what exactly do shift kits do
By shady milkman in forum Automatic TransmissionReplies: 6Last Post: 10-19-2006, 09:00 AM
