    Member speedracer25f's Avatar
    Bethlehem, Pa
    Midnight Blue
    Question about Pacesetter longtubes
    2 questions...I installed the black painted pacesetter long tubes and ORY pipe. Does the back coating usually start peeling off right away? If not then Im running lean maybe. Also anyone else have fit issues? My pipes rattle against the floor when Im on the gas, and the motor mount seems fine.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Stock motor mounts will cause the ORY banging issue and painted steel headers will rust almost immediately and flake off.
    Poly mounts/jet hot coating the headers will solve all your problems even though you probably dont like hearing that
    but the good news is headers have to come out to put in motor mounts ...
    about tree fiddy Shammer's Avatar
    Mansfield, Texas
    2001 M6
    i had the same problem if i would have known it would flake off i wouldn't have bought them. but they are on there now and im not going through all that again just to change them lol.
    War Machine BIG GUNS's Avatar
    St. Louis MO.
    00 Trans Am/Auto
    you may need to install another hanger on the right side. The LPP headers and Y that I'm getting, come with a passenger side hanger for the Y pipe.
    Shouldn't be too hard to weld a hanger on there though.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    you need a bump stop.thunderracing.com and ws6store.com have bump stops.
    Berwick, PA
    1999 Z-28 M6
    I have the Pacesetter LT's and the TSP TD's to be installed. Is it recommended for me to get the poly mounts? How is the install?
    Decatur Al
    99 Z28
    + 1 on the bumpstop hanger lot easier than motor mounts.
    Member wenn_du_weinst's Avatar
    Aug 2008
    South Dakota
    what if you strip the paint off and put like por15 or something I have headers on my pickup that did that and I want them to look better when I swap motors or am I just screwed
  1. Help: Pacesetter longtubes
    By RileyC in forum GTO
    Last Post: 06-03-2010, 04:26 PM
  2. pacesetter longtubes........ugh
    By jmatt07 in forum External Engine
    Last Post: 03-21-2009, 01:39 PM
  3. Pacesetter Longtubes? Y/N
    By b.lee in forum External Engine
    Last Post: 09-27-2008, 03:38 PM
  4. pacesetter longtubes
    By transws6am00 in forum External Engine
    Last Post: 05-10-2007, 03:38 PM
  5. Ls1 Pacesetter Longtubes
    By nc_z28_guy in forum Parts For Sale / Trade
    Last Post: 01-12-2006, 12:16 PM
