01-26-2006, 06:02 PM #1Member since 1999
- Dec 2005
- formerly FRESNO, CA.
pewter- 99 WS6 now belongs to X
head light door on 99 TA going up and down when remote lock pushed. Tech help pleas
can someone give me a fix or a link to a previous discussion?
01-26-2006, 07:04 PM #2
do you have a turn signal bulb out? mine did that because of that reason.
01-26-2006, 07:10 PM #3Member since 1999
- Dec 2005
I don't think so . . . I will check it out. It makes a ratcheting noise as well. I did replace a turn lamp bulb not to long ago. Thanks for the tip.
01-28-2006, 01:35 AM #4
One of your gears is going bad in either one of your headlight motors. Mine did the same exact thing when my headlight motor gear was going bad and then stop right when I installed a brand new one.
01-28-2006, 11:31 AM #5
Yep, its a headlight motor gear. I had the same issue. You could replace the gear but id probably go ahead and replace the whole motor.
01-28-2006, 01:59 PM #6
ok, maybe it was when i had to replace the passenger side motor.
01-28-2006, 02:00 PM #7Why? it's not hard at all to put a new gear in there. it took me like 30 minutes infact and everything works great now.
Originally Posted by Capster78
it's a lot more costly to do that too .
01-28-2006, 03:19 PM #8
they sell new brass gears that don't wear out. Look around for those
Power door lock doesn't work on drivers door..
By 99RedTa6spd in forum Firebird / WS6Replies: 3Last Post: 09-03-2014, 08:20 AM -
Door/trunk remote
By jag42420 in forum General HelpReplies: 5Last Post: 09-25-2007, 06:19 PM -
Remote Lock problem
By jagleaso in forum Stereo and ElectronicsReplies: 7Last Post: 09-14-2007, 09:34 PM -
Remote lock system freaking out
By Ram98 in forum Firebird / WS6Replies: 10Last Post: 09-04-2006, 10:38 AM -
problem with remote door lock controler help
By pgdn3 in forum CorvetteReplies: 1Last Post: 03-19-2006, 09:59 AM
