Results 1 to 2 of 2
Thread: Strut info?
    Tulsa,OK
    Quick Silver
    2002 Z06
    Strut info?
    Hello Guys,
    I was wondering how long struts will last. How do you know when they are bad? Same as shocks? If you push on the body to compress the shock and then it bounces instead of coming up and stopping its bad? Are the struts really any harder to change than the back shocks on the F-Body?
    Member Fastcar's Avatar
    Jersey Boy
    Dark blue metallic
    2000 TransAm
    Quote Originally Posted by gnomee
    Hello Guys,
    Ride and handling are very difficult to describe in writing; however if you push down on the car and it bounces instead of just coming back to the start point then I might suspect that your shocks/struts are shot. If you drive and hit a bump and the car "porpoises" (keeps going up and down instead of immediately damping the bump) then that's a fairly sure sign that you need need new shocks. It's much more difficult to change standard MacPherson struts than shocks because you need a spring compressor. The strut body itself is a suspension member and the spring sits on a spring mount that is part of the strut body. You have to compress the spring to remove the strut from the car. The replacement strut cartridge (the actual shock itself) threads into the strut body. You then put the strut back into the car.
  1. Do i need a new strut
    By cancam99ss in forum Suspension and Handling
    Last Post: 08-17-2010, 07:54 PM
  2. Anyone have any info? (Computer info)
    By blackSS01 in forum Almost Anything Goes
    Last Post: 02-01-2007, 01:44 PM
  3. What way does the strut go??
    By CitationZ06 in forum Suspension and Handling
    Last Post: 09-17-2006, 09:46 AM
  4. Strut Bar
    By camarostripes96 in forum Parts Wanted / Trade
    Last Post: 08-17-2006, 03:38 PM
  5. Strut Tower Bar
    By WS6RedDragon in forum Suspension and Handling
    Last Post: 11-22-2005, 12:06 PM
