Results 1 to 16 of 16
Thread: 2000 Z28....wont start
04-25-2009, 08:01 PM #1Junior Member
- kansas city
White- 2000 Z28
My camaro stranded me recently. I went to lunch and came out to go back to work and it wouldnt start at all. I put in the key and i get all the dash lights and radio comes on, then i turn the key and nothing.....no clicks or any other types of noises. I just replaced the starter in january, battery is nearly new too with no corrosion. I even had a new key made because alot of things i saw on the web stated the passkey could have been worn down over time. So i know this is a problem that could have hundreds of causes, i'm just wondering if anyone else has ever experienced this and/or any ideas on what the issue might be. I appreciate any help you can give!!
just some other quick info, car is a/t with 112k miles. never had any other issues before this. thanks again!
04-25-2009, 10:53 PM #2TJEA Retirement Home
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
check alt. mine did the same thing and it was my alt
04-26-2009, 04:47 AM #3
Starter may be hung. Bang on it with a hammer or big wrench.
04-26-2009, 06:09 AM #4Impounded
- Oct 2007
- Beaver Dam KY
Check all the fuses/relays. See if you can jump it.
04-26-2009, 05:52 PM #5James Bond
- Aug 2007
- Texas
does it have gas in it?
04-26-2009, 06:20 PM #6
ill it start in neutral? neutral safety switch bad?...
04-26-2009, 08:06 PM #7Go Wings!!
- Jul 2006
- Romeo, Mount Pleasant Michigan
Black- 1999 Camaro SS
Yeah this just happened to my jeep wrangler over the winter and like jray0305usa said it was the NSS. There are ways to bypass it, not sure how on a Camaro but on my jeep it was easy. A 4/12 inch lift helps when working on anything under the car however. I ended up installing a push button start on the floor connected to the positive battery lead and the positive terminal on the starter and it starts perfect when I cant get it to start with the key. Now that its warming up though Im going to fix it correctly.
1999 Camaro SS
SLP LM exhaust and lid, BBK ssi intake manifold, BBK LT Headers, custom ORY pipe, Eibach drag launch kit, RAM PG clutch and flywheel, Vector tune
351 RWHP 348 RWTQ
Coming soon - Moser 12 bolt w/ 4.11 gear
Livernois stage 2 heads with custom grind comp cam
04-26-2009, 08:07 PM #8Go Wings!!
- Jul 2006
by the way goodluck with whatever the problem is!
04-26-2009, 08:08 PM #9Exalted Cyclops
- Feb 2007
- San Diego, CA
VATS....
04-26-2009, 11:11 PM #10Junior Member
- Aug 2008
- LOS ANGELES
low battery starter solenoid or maybe the starter if you dont here no noises
04-27-2009, 04:01 AM #11
04-27-2009, 04:16 AM #12
2018 Tahoe - Silver - OEM
04-29-2009, 09:17 PM #13Member
- Oct 2008
- Miami, Fla
Spiral Gray- 2004 Auto Corvette
Smack the starter with a hammer mine did the same thing.
04-30-2009, 08:09 PM #14Junior Member
- Apr 2009
- New Jersey
Silver- 2000 Camaro Z-28
Replace the ignition switch
05-06-2009, 04:54 PM #15
Mine did that once,turned out to be corrosion on the ground cable-couldnt see it with the cable connected to the battery
05-07-2009, 10:39 PM #16
my guess is one of battery terminal worked themselves loose or is corroded, put a wench on it and see if you can tighten them. sometime they come just loose enough to have power and lights but wont handle the load of the starter.
let us know
Help: car wont start and now gauges wont work!
By AB'sLs1 in forum General HelpReplies: 52Last Post: 04-20-2013, 09:54 PM -
Help: help car wont start
By dany3350 in forum General HelpReplies: 18Last Post: 11-02-2012, 03:26 AM -
Help: wont start
By red96 in forum General HelpReplies: 6Last Post: 03-17-2011, 08:54 PM -
Car wont start
By juiced99ws6 in forum General HelpReplies: 3Last Post: 07-13-2007, 02:41 AM -
2000 Z28 cranks but wont start. What is the best Microtuner?
By Adam228 in forum General HelpReplies: 8Last Post: 10-20-2006, 11:39 AM
