Results 1 to 2 of 2
Thread: Engine size and CR calculator
04-24-2009, 03:55 PM #1
Hiya guys,
I was doing some research compression calculations and came across a rather informative site : http://www.angelfire.com/fl/procrastination/motor.html.
You basically enter your Bore, Stroke, how many cylinders (I'd imagine you all have 8 lol), Combustion Chamber volume, Piston dome (or dish) and gasket thickness. Then hit the 'Compute' button. It seem pretty accurate, but I have yet to compare it to the actual formula for figuring CR's.
My input .::.
Piston size in inches :: 3.900" (stock)
Stroke in inches :: 3.620" (stock)
Number of cylinders :: No brain(er)
Combustion Chamber in cc :: 72 cc
Piston dome in cc's :: -2.2
(Dome = positive,
Flat = 0, dished = negative number)
Gasket Thickness in inches :: 0.052''
Output .::.
Displacement :: 346"^3 (wow, didn't see that one coming) or 5.67 LI
Compression Ratio :: 9.3.....
so it seems like a pretty useful tool....
I've also posted this on LS1Tech.com as well as SmokinVette.comInformation Technology Super Sport
Suspension|T56|5.3|Twin TC66's|
04-26-2009, 12:25 PM #2
Stroke is 3.622"...
Engine Size
By ccarr1972 in forum General HelpReplies: 10Last Post: 07-06-2012, 10:01 AM -
D/A calculator....
By 0rion in forum Drag RacingReplies: 19Last Post: 10-07-2009, 05:51 AM -
Is the MAP table related to the size of the engine
By Doc99SS in forum Computer & TuningReplies: 7Last Post: 04-08-2008, 09:39 PM -
Tire Size Calculator
By hoss 2000 z-28 in forum Wheels and TiresReplies: 1Last Post: 03-21-2008, 07:54 PM -
Engine stand bolt size for ls1
By 95GreenZ28 in forum General HelpReplies: 1Last Post: 06-26-2007, 11:48 AM
